2nd April 2013, 02:28 PM
door open light on dash is shutting off and on
Hi! does anyone knows what could be wrong with the wiring connections to the door light switches? Doors are tightly closed, lights goes on when running on humpy-bumpy and goes off on another humpy-bumpy.
I've check all the door switches. All working good.
2nd April 2013 02:28 PM
2nd April 2013, 03:52 PM
alexx
hi! Does anyone knows what could be wrong with the wiring connections to the door light switches? Doors are tightly closed, lights goes on when running on humpy-bumpy and goes off on another humpy-bumpy.
check your globes the holders maybe streched,check the fuse might be a broken wire
might be just the truck my old one had that problem but never fixed it
2nd April 2013, 03:57 PM
Patrol Guru
Fiddle with your back doors. Mine had an issue with the "big" backdoor not being closed properly ( and the door ajar light flickering on and off) , banging it shut solved the problem. Ruff but effective
2nd April 2013, 04:01 PM
TimE
![Smile](images/smilies/smile.png)
Can also lead to the metal cracking.....
2nd April 2013, 04:13 PM
check the door is shut properly, you may need to adjust the door latch to close tighter to stop the light flickering.
2nd April 2013, 06:25 PM
Mines the same. My trouble was the back door sensor. At first i put a ball of blue tack in the rubber to beef it up a bit to stop it, but it came back again. I find that stuff moving in the back would push on the door making it flash.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
![Tongue](images/smilies/tongue.png)
3rd April 2013, 05:12 AM
put a fridge magnet over the sensor in the barn door and problem solved just increases pressure on switch
OH LEATHER IS NICE
![](image.php?s=a7bc526d3c44086d57a45bc45874274d&u=256&type=sigpic&dateline=1352567496)
The Following User Says Thank You to my third 256 For This Useful Post:
3rd April 2013, 06:58 AM
#8
Mine have the same problem. I checked all what you say but still doing the same
4th April 2013, 01:20 PM
#9
TimE
I've tried all like what in the many replies here before i had the post. Works at times but sometimes doesn't. It irritates me sometimes. I ignore most of the time. I just can't bring on the alarm if i step out with the light on before i shutdown the engine. Running on a rough road would solve it before i park and after banging it lightly but doesn't flick off . hahaha! I find it more gentle than banging the doors so hard.
Thank you for all replies. I will post again when I fine an ultimate solution or when someone post his.
4th April 2013, 01:26 PM
#10
my third 256
Pressing very hard on every sensor is tighter than any magnet pull. it didn't work. Thank you.
