Results 1 to 10 of 15
Thread: spot lights
    Mar 2013
    spot lights
    hey every one trying to find out wot sort of relay i need to hook up 100w spot lights
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    30 - 40 amp relay will be fine as your only going to be pulling low amps
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    I'd go 30 amp relay, have a look here too
    http://www.alanhorvath.com/54chevy/u...ing_relays.php
    Expert Lieney's Avatar
    Adelaide,SA
    100W spotlights draw 8.33A each.
    A total of 16.66A will pass through the power and earth side of the circuit and relay.
    A 30A relay with one main input and 2 outputs would suffice.
    Ensure you fuse the supply to the load and switch circuit using 20A-25A fuse.
    If you are fitting driving lights, the power for the switch is to come from the high beam circuit, if fog lights, from the park light circuit.
    Or just free-lance it
    Ensure your wire is capable of carrying 20A to each light and to wherever you earth each one.
    Ensure that if your relay has one input, you either run 2 x 20A wires, or wire suitable to carry 35A.
    The switch side, of the circuit will only draw bugger-all.
    06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
    Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
    Feb 2013
    Broadford VIC
    And a quality 30 amp, not a supercheap $2 relay
    Mar 2013
    thanks guys
    brisbane
    Quote Originally Posted by Lieney View Post
    Isn't it illegal to have fog lights on all the time theyre only permitted when there's fog.. I wouldn't be going off the park lights unless you put a switch on also
  9. The Following User Says Thank You to megatexture For This Useful Post:
    BigRAWesty (11th April 2013)
  10. #8
    Western suburbs of Melbourne
    11 Post(s)
    spot lights
    Quote Originally Posted by megatexture View Post
    This would be correct, I went through a RBT bus and the coppers asked me to turn them off or he will fine me. "As fog lights can only be used in adverse conditions where appropriate. "
    Quoted by the officer.
  11. #9
    Expert Dominator's Avatar
    Oct 2011
    spot lights
    I believe all driving lights must have their own switch. Even if they are triggered by the high beam.
  12. #10
    spot lights
    Quote Originally Posted by Dominator View Post
    That is true, on their own switch triggered by high beam is the only legal way to have them.
    If you're happy and you know it tap a post!
