Results 1 to 10 of 13
Thread: Tb42 revving high after backfire
    Feb 2013
    Hello
    My patrol has started to idle high, it back fired on fuel last night, and since then it holdes 1800-2000 rpm all the time got or cold. Started it up this morning and it holds 1200-1800rpm and won't go down after warming up.
    What could this be and is there a solution, from what iv read the tb42 has a few problems with the auto choke ?
    Any help would be appreciated
    Thank you for your time
    Marti
    174 Post(s)
    Have no idea if this will apply to a Patrol, but a few years ago I had the same thing happen to a Ford XF efi wagon I had running on gas. What had occurred was that the back fire had distorted some sort of 'flap' in the air box. A new air box was going to cost an arm & a leg, but a local bloke managed to tweak the existing flap & solved the problem.
    Patrol Guru
    Apr 2011
    Melton
    Is it a carby or efi motor
    is it dual feul and the idle is high in LPG? - possible blown mixer
    Patrol Guru Airstrike's Avatar
    Feb 2011
    Re: Tb42 revving high after backfire
    Hi mate sorry to hear. I had the same issue with a TB42E big enough to dent my bonnet from debris. When this happen the car went into survival mode with the base idle at 2k. It ended up being the MAF.
    tip it tap it slap it
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah as said above, a backfire can damage parts of the fuel system. I reckon it would be worth checking for any distortions in the butterflies or airbox area. Also look for any leaks that may be letting air in.
    FanTapstic!
    Hello from Under Down Under!
    Feb 2013
    It is a carby, idles same on fuel as it does gas, no flaps or visible damage anywhere, I pulle the auto choke apart and cleaned it, still idles high, on my way home 20 mins into my drive it settled back to normal ish idle, fuck knows whays happened. Ill look at the throttle butterfly's today and see if
    Anything going on there
    Patrol Guru
    Apr 2011
    Melton
    I might have jammed the fast idle cam in the wrong position (its the white thing on the side of the carby below the autochoke.)
    Feb 2013
    Ok anything I can do to rectify the problem
  10. #9
    Feb 2011
    Quote Originally Posted by GQ TANK View Post
    Sorry mate carby not for me I sincerely hope its an inexpensive fix.
  11. #10
    Mine loves to do this.
    Simple fix just a PITA to get to.
