Results 21 to 30 of 33
Thread: Fuse box
    Awesome mate... I'll let him know. I he was saying something about the relay being a possible issue... I'll just show him your post... Cheers mate!
    Sent from my GT-I9210T using Tapatalk 2
    Oct 2011
    Essendon
    No worries at all mate. I hope you solve it.
    Cheers,
    Drew
  4. #23
    Well we cleaned all the contacts in the relay of the hid kit. He seemed to think they could have been dirty... Seems fine so far.. Another test of time I guess
  5. #24
    Nope didn't fix it... Sigh.. It's getting to me. Think we need to just change the relay completely! Could it be the switch in the truck? If I turn lights on then off on off on off it will turn on eventually and stay on without a hicup for a day or two then go back to one light. Has to be either the relay or the switch yeah?
  6. #25
    Oct 2011
    Essendon
    Hmm.....sounds like something lose perhaps.....almost sounds too random to be anything else. Is it a sealed relay unit.....this is what mine looked like when I pulled it apart ImageUploadedByTapatalk1354845775.609807.jpg
  7. #26
    It is a sealed relay unit with a loom that plugs in underneath...
  8. #27
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    the GQ's never had relay for the Lights
    power from Battery to the Combo Switch to the headlights -
    if there is a relay there - it is aftermarket, and possibly screwed
    my suggestion would be -
    pull the Combo Sitch out from the column, strip it down and clean the contacts and re-grease them, then replace,
    unless you want to put in a complete new loom for your lights, I would be reverse engineering the wiring from that relay to find out what its up to......
    cheers
  9. #28
    Oct 2011
    Essendon
    How did you get on?
  10. #29
    Havnt had a chance to get the relay swapped over yet, but but I am thinking the switch needs to be stripped and cleaned. If I turn it on and it doesn't work I then just turn the switch on and off a Cpl times and away she goes. It will then work fine until switched off. It only does it every now and then.
  11. #30
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Let me see if I have this correct.
    Your problem of having no headlights is now fixed and you now have HIDs fitted?
    Now your problem is one HID doesn't turn on sometimes or does it just switch it's self off?
    The other light works normally all the time?
    If this is correct your problem can not be in the headlight dipper switch or the vehicles original wiring.
    When HIDs are installed a separate wire harness is also installed, so if one HID works and the other one doesn't then the problem is with the HID install.
    Is it always the same light that doesn't work?
    This is a common problem with the poor quality HID kits.
    At night look at the wire harness running from the ballast to the bulb, then get someone to turn the lights on, can you see a spark jumping from the wire to the body of the vehicle?
    You could also try swapping the bulb and the ballast with the other side one at a time to isolate the problem.
