1st December 2012, 12:43 AM
Changed the battery now car won't turn over
Hi guys more dramas, changed the battery and everything works but the car won't crank over??
I have checked some of the fuses but they look ok.
1st December 2012 12:43 AM
1st December 2012, 02:43 AM
wont turn over at all?
you have dash lights?
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
1st December 2012, 06:43 AM
Hardcore
Get too small a battery maybe
Such is the rule of honour.
1st December 2012, 07:07 AM
just had a look at the specs and it is only 675 cca where as the n70zz is 720cca
so i would agree with macca86 swap the batteries you have over so the auxilery is used as the main starter (thats the ones in the battery trays)
or link them togeather as you can do with the redark isolator 0r jumper leads
hope this makes sence
OH LEATHER IS NICE
1st December 2012, 11:22 AM
mine is a 710cca so should be ok and i spoke to the guys at cat and thats the one they sell for patrols, everything works but it wont crank at all??
1st December 2012, 11:44 AM
from memory you need the N70ZZL as the N70ZZ has a reverse polarity so check you have the correct polarity. fingers crossed im wrong
1st December 2012, 11:56 AM
The 747
Think you're right mega, mine was like that.
DIAL-A-TAP
1st December 2012, 12:14 PM
#8
I checked when i put it in, the polarity is correct, I have power to everything it just does nothing when i turn the key to start, glow light goes out has lights stereo but wont crank at all, when i get home i will take the battery connections again and make sure the little relay contacts are clean and getting a good contact, cant be much else.
1st December 2012, 01:39 PM
#9
There is a fuse from memory its 35amp red one that sits next to the battery in that black plastic case, which should be labelled starter, just double check it and make sure it hasn't blown. Mine being a safari it's 24v so could be different on a 12v.
The Following User Says Thank You to HippoNZ For This Useful Post:
Stropp (1st December 2012)
1st December 2012, 04:37 PM
#10
I dont know anything about patrol security but could your keys need reprograming?
