8th September 2012, 12:30 AM
#11
RIP - valued member and true gentleman of this forum that will be missed by many!
can you leave the shock alone, and use coil spring compressors to crush the coil and get it out? Even trap the coil in the compressors by jacking up the axle and using it to squash the coil?
NOTE: in saying this I have not done it, I do not know if it is safe, and I don't know what it would be like releasing the tension from the spring compressors. Nervous, I suppose, there would be a bit of energy stored up in the system :-)
"As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
The Following User Says Thank You to Silver For This Useful Post:
dan dog (8th September 2012)
8th September 2012 12:30 AM
8th September 2012, 01:52 AM
#12
I will have to cut it off anyway as there's no room in its location to tap a new thread onto it. I think previous owner has cross threaded it when putting shocks in. Nut came off easy. When I removed shock I seen the stripped thread. I'll put a pic up so you can se first hand. Appreciate the help guys.
8th September 2012, 02:04 AM
#13
8th September 2012, 02:08 AM
#14
Silver
spring and shock are already off. im putting new stuff on it. but this has really put a damper on my day.
8th September 2012, 02:30 AM
#15
dan dog
yeah, just worked that out, I think :-) I had the bull by the tail and thought we were talking about a spindle ended shock rather than the mounting pin for an eye end.
8th September 2012, 02:33 AM
#16
while looking at it in daylight, is it worth checking to see if it is attached like a wheel stud, ie pressed in from behind?
8th September 2012, 02:49 AM
#17
Silver
EEK. have to pull fuel tank out to do that. but not a bad idea. ill check the drivers side one cause i think it was clear of the fuel tank. if so probably lot easier to remove tank and knock a new one in than cutting and welding. i'll keep you posted on that one. thanks
8th September 2012, 03:01 AM
#18
Curiosity got the better of me so went had a look. And there welded in. So looks like its back to the drawing board.
8th September 2012, 03:33 AM
#19
Having a look at that pic, Im thinking it maybe possible cut a hole in the floor pan to gain access with a dye & retap the thread that way. I know cutting the floors not everyone's & it may very well not be yours either, but im thinking of it from a work involved type of aspect & lets face it. a hole in the floor is quite easy to cover & seal up as apposed to the amount of work involved in cutting it out & welding in another one.
Just a thought.
8th September 2012, 03:50 AM
#20
Thinking out side the box. Good one. May well be a option. At the moment can't sleep trying to get my head around how much of a bast@rd of a job its going to be. (Which ever way I go about it).
The Following User Says Thank You to dan dog For This Useful Post:
patch697 (8th September 2012)
