Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: h.i.d 's make my stereo crackle!!!!
    Expert Boagie's Avatar
    margaret river wa
    Cool h.i.d 's make my stereo crackle!!!!
    Hey guys,since i have put my h.i.d light's on,the radio makes a hissing sound.It makes it almost impossible to hear the radio.Is this normal? I went and saw the brother inlaw(who also just put some on his croozer and it does the same thing,but not as bad.Any ideas as to what this is ? and to be able to cure it??Any info greatly appreciated!!
    You don't drive...you patrol!
    99 gu dx 4.2 diesel cab chassis - "THE GOLD DIGGER"
    All I can say is that no, it's not normal. Sounds like you've got some weird interference going on.
    Re-check your connections, are they xenon or bi-xenon???
    Any decent noise suppressor filter capacitor whatever you like to call it should solve the problem.
  5. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
    Boagie (19th July 2012)
    margaret river wa
    Sorry threedogs refresh my memory..does that mean hi/lo or spot if so mine are hi/lo
    Hi/Lo Gool as suggested go to auto shop and get a suppressor, that should stop it, mine did that a few times as well but not any more, go figure
  8. The Following User Says Thank You to threedogs For This Useful Post:
    Boagie (20th July 2012)
    Jul 2012
    best to get a filter or re-route ur wirring of the hids as far away as possible from stereo/antanna etc
  10. #8
    Hardcore
    central coast nsw
    sound like a short on circuit board, internal fault, Id be contacting seller.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  11. #9
    Advanced dsmith's Avatar
    Jul 2012
    I've had some experience with auto electrics... the problem occurs mostly with cheap HID kits. They introduce what is called 'ground noise'. As mentioned you can install an in-line 'filter/ground loop isolator' to the earth cable on your head unit that will solve the issue.
  12. #10
    Heritage park, qld
    Maybe a better/stronger earth would help?
