I put mine in for a bit of a touch up on the motor.
New Tipan 3 inch pipe system.
New supped up injectors for the extra HP.
New heavy duty out back clutch.
And a new gearbox.
I have just picked up the Patrol 4.2 D 2001.
Impressive numbers off the machine after the work has been done.
Prior to the Dyno touch up.
106.8 KW @3820 RPM
300 NM of torque 2265 RPM.
After the dyno touch up.
128 KW @ 3680 RPM
420 NM of torque @ 2870 RPM.
Impressive result from the new parts.
A new motor im told will be around 104 to 110 KW of power.
In theory i should not know im towing anything.
