1st June 2012, 10:32 PM
Thermostat stuffed??????????
My ig girl doesnt seem to want to get past about quater on the tem p gauge--does this sound like the thermostat is stuck open???
You don't drive...you patrol!
99 gu dx 4.2 diesel cab chassis - "THE GOLD DIGGER"
1st June 2012 10:32 PM
1st June 2012, 10:40 PM
Dribble Master
Same happened with mine a while back , temp didn't seem to rise and fall like it does with a working thermostat, my thermostat was stuck open ..........
The Following User Says Thank You to Clunk For This Useful Post:
1st June 2012, 10:41 PM
My GQ never gets above a quarter only when the AC is on and then it sit at about a third.
check water temp with a thermometer in case the gauge is faulty
1st June 2012, 10:44 PM
what should temp be??--it was fine this morn,but stuck on 1/4 tonight--it usually sits just under half..
1st June 2012, 11:14 PM
Dribble Master
Mine usually sits between around 1/4, when i push it hard or when it gets hotit gets to between 1/2 & 3/4, thermostat opens then slowly drops down tto just under half..... but i alwaysback off and let cool down a bit more. I need to fit a proper temp gauge really instead of relying on the crappy standard on.
Mine is a petrol though boagie, so not sure on the differences there
