Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Couple of quick Q's about the GQ
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Two down, one to go.. Good on ya mate!
    Q1
    you probably have a dodgy had break switch on the leaver
    or
    you don't have enough brake fluid in the reservoir.
    the hand break light will come on if you are low on fluid.
    did you replace the break hoses?
    *edit*
    should have read you fixed it
  4. #23
    Quote Originally Posted by BLKWDW View Post
    How did you find out it was the body mounts. Just visually inspecting them or were they loose cos i'm having the same prob with my car
    yeah just a visual check, but also you can lift up the carpet and pop the pugs off where the body mount is and see if there is movement on the bolt (scuff marks) but usually there isn't any tell tails like that.
    just stick you head underneath and if they look perished... they are.
    like i said.... it's a factory option
  5. #24
    Expert GQPorkroll's Avatar
    Hunter Valley NSW
    Yeah same here, just figured where the noise was and had a look in that area.
  6. #25
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by growlers71gq View Post
    Hand brakes mechanical not hydraulic so fluid won't effect it. Will be the switch stuck think you'll need to remove centre console to access
    Tappin N Crappin
    Yes it is mechanical, but I agree with munter.....the handbrake light will light and stay lit if you have low brake fluid in the reservoir
  7. #26
    Hunter Valley NSW
    GQ, I'm not sure what the answer was, as I pulled my console out and sprayed contact cleaner on the switch ad cleaned it up with a wire brush and also removed the cap and topped up the reservoir, although it was still above the minimum line. The handbrake switch was pretty corroded so I'm guessing that was the issue.
  8. #27
    Expert bordertech's Avatar
    Bordertown
    Quote Originally Posted by Ade View Post
    Q1: If brake fluid and hand brake switch are ok, there is vacuum switch on the left hand side of the alternator (TD42) with. Small vac. hose attached to it from the vac. pump at the back of the alternator, check the hose for cracking or the switch itself might be faulty..
    Ade
    Is the little metal tab on the handbrake arm that pushes on the switch bent up or broken off?
    I love terra firma - the less firma the more terra
  9. #28
    Feb 2011
    Brisvegas
    The body mounts on Silver had got to the point where the small barn door would sometimes touch the rubber bumper over rider.
    If you take a look at the mount, there is, from the top, the body. Then a rubber bush. Then the chassis outrigger or whatever it is called. In Silver's case next there was a gap. Then another rubber bush and a big steel washer dangling in space :-(. The space is mostly created by the failure of the washer between the chassis and the body.
    I had the lot replaced with factory - yes, a lot less noises now, and feels different to drive. The bloke who did it has been on here, did a good job at a fair price, in my opinion, is well set up to do the work, and is based in Morayfield. PM me for details as I don't know what the rules are. I have no association with this bloke or his business, except getting this work done after seeing his post re certifying/engineering mods.
    If you are going to do it yourself, it is worth searching on here as some other forumites gave me some great how to tips.
    I got the lot replaced, as I wanted everything back to the right height/spacing from the chassis. According to internet searches away from this forum, some people do interesting things including just doing up the fastenings after shortening any crush tubes. There have also been some mutterings to do with bath plugs :-)
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  10. #29
    Thanks to all for the hints on the body creaking. Same problem with mine. Will take a look...
