Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: MK Patrol 1985..I just bought
    Quote Originally Posted by cybernout10 View Post
    Read somewhere in the forum trannies get busted when they get to 300K...any comment much appreciated.
    I would not worry too much. From 85 on they had ironed out all the steering & suspension problems and it will no doubt be a 5 speed so should be a good strong box with a good strong Transfer case.
    The only problems I am aware of is if they have been used towing in 5th gear a lot they can wear and sometimes pop out of top gear.
    First job should be to drop all the oils (gearbox, Transfer, Both Diffs and Engine) out and inspect them for water ingress and fill with new oil. Starting fresh you know whats in them.
    Check around windscreen/firewall and also Front floors where the body is bolted to the chassis as well as the Radiator supports for rust. The other spot is around the rear side windows.
    Looks like a nice ride.
    Cheers Ric
  2. The Following User Says Thank You to Ric For This Useful Post:
    misha1973 (16th March 2013)
  3. #22
    Mar 2013
    Serbia
    Johan, how much you L28 with LPG consumes? I am considering getting one here, with LPG.
  4. #23
    Dec 2018
    Italy
    looks good mate. i am in the same boat, i bought mine from a mate but had no idea even which model it was. going to be on the forum jolly often pestering you guys i think! best wishes
