Results 1 to 10 of 12
Thread: GU Headlight Fault
    Advanced Crusher_AU's Avatar
    Sydney
    GU Headlight Fault
    Hi all
    I have an issue on my GU TD42. The L/H headlight will light up both high and low beam when low beams turned on, also the high beam indicator on dash will light dimmely..
    When I switch to high beam all ok..
    I got a second hand stalk from the wreckers but it didn't fix the problem . Could just be bad luck..
    Is there picture or diagram showing the pinout for the stalk connector.
    Mick
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Did you try a new Headlight Bulb ?
    Sydney
    Yes... that was my first try... thought it might have been a simple short in the bulb
    Brisbane,QLD
    12 Post(s)
    So assume you checked the plug connection (3 pin) that goes onto the bulb then, no melting of the plastic etc ? , the other thing that comes to mind is perhaps a back feed from your spottie relay trigger wire (if you dont have em ignore this one, lol)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Check the earth connection in the L/H headlight plug.
  7. The Following User Says Thank You to Yendor For This Useful Post:
    Crusher_AU (3rd April 2012)
    Sydney
    Quote Originally Posted by 04OFF View Post
    Yes I found the 3 pin connector all burnt and charred, I replaced it thinking that would fix it but no luck... (this was before I replaced the combination switch), when I did a volt check at the plug I get 12 volt on both HB and LB when LB turned on..
    I just reviewed the wiring diagrams... HAS TO BE the combination switch.. I think I just lucked out with the one from the wreckers.... will pull it today and check its switching....
    It was funny the wreckers in Revesby wants $40 more than Nissan genuine for the combination switch .
    The spottie relay is on the HB for the RH HB and has been there for many years trouble free...
    If the combination fixes this I will upgrade the wiring.
    I think I have caused this by running higher watt bulbs than the harness could handle... original lights are so bad in low beam.. Standards are in there now...
    Sydney
    I will check that today thanks....
    I think it should be ok as HB works fine....
    Mick
  10. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Crusher_AU View Post
    Was this with the plug stilled plugged into the bulb?
    If so, try doing a volt check with the plug disconnected.
  11. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I think you may have put the pins in the wrong place when you replaced the plug.
    I think you have the Red wire with a Blue trace and the Black wire in the wrong positions.
  12. #10
    Sydney
    No pins are correct.. triple checked...
    I am getting power to both the HB and LB pin on the LH headlight only....
    Now I have the diagram I am sure it is the combination switch and I just lucked out at the wreckers..
    In the diagram the red lightening bolt shows the area of the switch I am sure is shorting to both LB and HB... and as the HB indicator is driven from here makes even more sense as to why when in low beam my HB indicator lights up dimmley.....
