9th February 2012, 10:00 AM
#11
I've fitted an OME 2" lift with front sway-bar disconnects:
Sway bar connected
Sway bar disconnected
Not a great deal of difference, I leave them connected most of the time unless I'm on a really nasty track.
I use my car for a fair bit of touring so much prefer to have the sway bar connected, you can drive without it but its not ideal.
9th February 2012 10:00 AM
9th February 2012, 05:27 PM
#12
Smart like tractor
BearGUST
Sway bar connected
by the look of the 2 pic. I'd say that the limiting factor is the shock length, that is why you see minimal difference
96 GQ coil/Cab
08 G6eT
9th February 2012, 06:21 PM
#13
Banned
Ben-e-boy
Agreed - can see what appears slightly more compression on the front, but no real difference in the travel of the rear ...
9th February 2012, 06:44 PM
#14
Smart like tractor
Bigrig
I see that too
96 GQ coil/Cab
08 G6eT
9th February 2012, 06:45 PM
#15
Can some one tell/show me what a manual sway bar disconnect is?
I have hear about them but I just do not understand it.
"Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
9th February 2012, 06:51 PM
#16
Smart like tractor
Mazodude
there is a lever next to the the driver seat. if you dont have one you need to buy disconnects from superior engineering. you need to get under the car to disconnect them. as good as they are I found them abit useless when disconnected as the became the lowest point of the vehicle. I like driving rock and ruts. more technical stuff and they were just asking to get ripped off
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
Mazodude (9th February 2012)
9th February 2012, 07:09 PM
#17
Ben-e-boy
ahh. Seeing as I love rocks and ruts, I wont bother then.
Thanks Ben-e-boy
9th February 2012, 08:08 PM
#18
Patrol Guru
Thanks guys, all good ideas, i want to keep the truck legal i cant be bothered with the the cops hassling me.
18th February 2012, 02:08 PM
#19
To get maximum articulation, you need:
1. Replace the front radius arms as they bind up. Something like the superiour engineering superflex radius arms
2. Replace the rear lower control arms with longer links and a new welded chassis link, again superiour engineering have a kit
3. Remove anti sway bars or use quick disconnects
