21st September 2012, 04:45 PM
#11
I had the same problem on my 06 GUIV 3.0L TD. Replaced the belt and the idler pulley and bearing (from repco, not the whole assy like Nissan sells) with no result. I then read the above and removed the shims inside the A/C clutch and it doesn't squeal anymore! Thanks Rodney for the tips.
Note: I had to use a puller (no, not Bigrig) to get the clutch off the compressor.
Cheers,
Steve
21st September 2012 04:45 PM
21st September 2012, 08:02 PM
#12
Just curious did you put oil in the new compressor and how long did you have the a/c lines open for?
24th September 2012, 02:02 AM
#13
Idler bearing on 90 mod TB42 GQ maverick is replaceable.
Well the 1 on sons mav is.
The idler bearing No was 6203DU2.
Anyone know the clutch bearing No?
ebay has AC stuff
Reason: more
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
24th September 2012, 08:49 PM
#14
