Page 1012 of 1049 FirstFirst ... 125129129621002101010111012101310141022 ... LastLast
Results 10,111 to 10,120 of 10488
  1. #10111
    The master farter
    mudski's Avatar
    462 Post(s)
    Possibly shorted out the transfer pump. I have heard of this issue over the years, from memory, some just installed an aftermarket pump and wired it in. How long did you disconnect the battery for? Just reading on the interwebs someone had to leave it disconnected for an hour for it to work.
    The sub tank sender units do have a level switch so when the tank is empty it will shut off the transfer pump? Might be a dodgy sender unit?
    Cuppa (27th November 2021)
    Ballarat, Vic
    174 Post(s)
    Shorted out transfer pump sounds like a possibility. Can thy short out internally? Whilst up on the Tele Track one thing I tried was running 12v direct from battery to pump. It ran, but far more slowly than I recall hearing running in the past.
    Can anyone suggest any further tests I could try to determine whether the pump has or is turning it's toes up?
    Can anyone point me to a suitable transfer pump which will fit into the same space to keep things nice & simple.
    A Nomadic Life (Blog)
  5. #10113
    Jun 2018
    24 Post(s)
    Try this @Cuppa
    Pulling fuse #24 worked to reset the sub tank warning light. It also resets the odometer, which I was hoping to avoid, but it's certainly easier than removing the negative battery cable.
    From this thread "fuel system": http://www.nissanpatrol.com.au/forum...ad.php?t=46132
    This would allow me to reset the warning light, push the switch and have the green light come on and the pump work for 15mins to 1hr.
    I haven't invested the time to try to fix mine, so the warning light is still on and I'm not using my sub tank, but I certainly don't need it like you do!
  6. The Following User Says Thank You to Cremulator For This Useful Post:
  7. #10114
    Ballarat, Vic
    174 Post(s)
    Try this @Cuppa
    Had the battery disconnected overnight & have also tried the removing the 7.5A fuse as per the thread you linked too. No difference. Am thinking now it more likely to be the sub tank sender which is the problem. If so it will have to wait. I'm not up to dropping the fuel tank myself. Once all the pain & discomfort from my recent time under the car has faded away I might try hooking up the transfer pump direct to a 12v source & try pumping into a container just because it is reasonably accessible & to tell me whether it is working properly with a reasonable flow rate. The fact that it sounded like it was running slower than usual out on the track may have been due to the, at the time unseen, partially severed wire.
    This control box thingo is well out of my comfort zone (& understanding), but I cant see why a failed or failing pump would cause the sub tank fuel gauge to not register anything, but I suppose anything is possible....... even a coincidence of 3 things 1. Failed or failing transfer pump 2. Failed sub tank sender unit 3. Damage (now repaired) to transfer pump wires.
    One thing keeps going around in my head. When I repaired the transfer pump damaged wires the sub tank fuel gauge worked - but only once. After switching off the ignition & back on again I have been back to sub tank warning light & no fuel gauge. Seems inconsistent with a failed sub tank sender unit...... but??
    Is there any way of diagnosing the sub tank sender unit without removing, & replacing/substituting? If not is sub tank removal on a Cab chassis a big job (or not) for a well equipped workshop? It's tempting to bypass the control box with a simple on/off switched transfer pump, but I need to be able to watch a gauge if I were going to do this.
    Come back Yendor! (For those who didn't know him - he was the best auto electrical resource imaginable , on this forum - offering step by step diagnosis on all things to do with Patrol electrics).
  8. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    Cremulator (28th November 2021), Maxhead (28th November 2021), mudski (28th November 2021)
  9. #10115
    The master farter
    mudski's Avatar
    462 Post(s)
    Yes @Yendor aka Rodney was, well still is, a god at this stuff.
    To rule out the pump, can you "hard wire" power to the pump to see if its working? Then atleast you know if its the pump or something else. use some twin core wire direct from the battery and to the pump...
  10. #10116
    175 Post(s)
    @Cuppa
    Could this be the switch itself in the cab?
    I recall @the evil twin once talking about the switch being a culprit in many sub-tank issues.
  11. The Following User Says Thank You to Hodge For This Useful Post:
    Cuppa (29th November 2021)
  12. #10117
    472 Post(s)
    Dust/moisture compounded cement like overload in my beloved very first 2000 GU leafy work ute sub tank dash switch was the culprit. Apologies if I haven’t read properly symptoms above but many early working GU’s I’ve known too also changed to aftermarket manual ON/OFF pump switches which unfortunately do take highway concentration to turn off again when visually transferred but faithful +\-
  13. #10118
    Ballarat, Vic
    174 Post(s)
    @Cuppa
    Anything is possible. Could be more than one problem? I have decided that the first priority is to get the sub tank fuel gauge working again. Could be some time before that happens though - no auto sparkies around here - might have to wait until the end of the Wet. Rains have started. Can manage with a single tank for the time being.
    Finished fitting two new rear cameras & a monitor today. The old ones had become unreliable after almost 10 years & lots of corrugations. Fitted a 30 degree rear vision camera for driving (https://www.nassecurity.com.au/30-vi...-r-cs212w.html & a tiny 170 degree one (https://www.ebay.com.au/itm/183696421838) pointed at the tow hitch to assist with hitching up. A new 'mirror monitor' made up the package.
    One job left to do (excluding the subtank issue - arthritis makes under car work increasingly difficult). After 10 years of use our hot water system has developed a leak, cause is a lime scale build from all the outback 'hard' water in the tempering valve assembly. Replacement on it's way, hopefully on this Wednesday's mail plane. A messy job which will be good to get out of the way. We got by for a couple of months by bypassing the hot water system, but Mrstea does like having hot water. After that the car will be stored on (relatively) high ground to hopefully avoid the flooding when the Wenlock breaks it's banks.
    This is where we are. On the northern bank of the Wenlock, just the two of us at Moreton Telegraph Station.
  14. The Following 6 Users Say Thank You to Cuppa For This Useful Post:
    Cremulator (29th November 2021), MB (29th November 2021), mudski (29th November 2021), pollenface (30th November 2021), Stropp (29th November 2021), Touses (30th November 2021)
  15. #10119
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    2008 CRD Auto Wagon
    Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
  16. The Following 2 Users Say Thank You to pollenface For This Useful Post:
    MB (5th December 2021), mudski (2nd December 2021)
  17. #10120
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    You can fix that calcium buildup easily with descaler (as used to descale kitchen kettles etc). The valve will almost certainly be perfect except for that buildup hindering its operation. I have done this on domestic hot water systems a couple of times.
  18. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    Cuppa (30th November 2021), MB (5th December 2021)
Tags for this Thread
