Results 1 to 10 of 10
Thread: Nulon rear main seal stop leak stuff
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I suspect I have a (slight) rear main seal leak.
    I'm curious about that Nulon stop leak stuff. Do you idle it for a bit and then drop the oil or just leave it in there?
    2008 CRD Auto Wagon
    Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I've used Nulon on the Falcon, after a crook mechanic (MUPPET!!) fitted another engine without swapping the seal or even replacing the rear welsh plug. That was a long time ago and the leak has stopped. Silver seal also plugged the welsh plug.
    Nov 2019
    Perth
    5 Post(s)
    Well the nulon stuff works great, I used 2 bottles at 100ml/Litre and deducted that amount from the sump capacity to get it spot on (I like maths), I'm starting to miss the smell of engine oil dripping on the exhaust
    2008 CRD Auto Wagon
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by pollenface View Post
    So how did you go about it? Leave it in?
  6. #5
    Nov 2019
    Perth
    5 Post(s)
    Yeah left it in, it's been there for 1500kms so far.
    2008 CRD Auto Wagon
  7. The Following User Says Thank You to pollenface For This Useful Post:
    mudski (22nd December 2021)
  8. #6
    Ballarat, Vic
    174 Post(s)
    Similar with stop leak stuff I put into a radiator once. On A Holden HZ ute with a 186. I had topped up a hot engine & heard the 'crack' before seeing water dripping from the exhaust. Instructions said put the stuff in, run for a while & then drai coolant & replace it out. It didn't work, so I tried again & left it in. Never leaked again.
    A Nomadic Life (Blog)
  9. The Following User Says Thank You to Cuppa For This Useful Post:
    pollenface (23rd December 2021)
  10. #7
    Advanced
    Feb 2021
    Used it years ago in old gq ute. Rear main was leaking real bad, chucked the seal replenisher in left it for couple thousand drained oil then the thing didn't leak for tens of thousands of ks then put new rear main when did clutch!! Think I used liquimoly but its all the same stuff really
  11. The Following 2 Users Say Thank You to wagu89 For This Useful Post:
    MB (22nd December 2021), pollenface (23rd December 2021)
  12. #8
    Legendary
    194 Post(s)
    This stuff works by chemically attacking the seal and forces it to swell. What I wonder about is the effect on seals there are not leaking, do they swell and deform also?
  13. #9
    Nov 2019
    Perth
    5 Post(s)
    lets find out ....
    2008 CRD Auto Wagon
  14. #10
    Nov 2019
    Perth
    5 Post(s)
    I finally got around to getting this leak fixed. Turns out it was the tappet cover seal (and it was spilling down the back of the motor), not the rear main ... haha I have a habit of assuming the worst case scenario and rolling with that.
    2008 CRD Auto Wagon
