Results 1 to 5 of 5
Thread: wiring reverse camera
    May 2016
    8 Post(s)
    Hi all where do you pick up a reverse sensor wire ? found the blinker fluid . but still looking for a reverse sensor for the reverse camera . GU series 11
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    This is a pic of my recently removed dash. It was a long time ago but I’m pretty sure I got the reverse signal from the yellow wire coming from the middle blue relay on the left.
    You’ll need to drop the glovebox.
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
    Tip12345 (14th July 2021)
    If the camera is at the back and needs power which then feeds the camera and the screen then take it straight off the reverse globe at the rear. Relay if you are concerned. Take the opportunity while.you are there to relay in a camp light/reverse light too.
    You have to run a wore to the front from cam to screen anyway so take it from the back.
  7. #4
    Jun 2018
    24 Post(s)
    Here's how I wired up my reverse camera, taking the feed to trigger the head unit from the same yellow wire in the passenger footwell that @jff45 mentions.
    http://www.nissanpatrol.com.au/forum...d.php?p=796233
  8. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    the evil twin (13th July 2021), Tip12345 (14th July 2021)
  9. #5
    Agree ^^^^
    Yellow wire on passenger side loom is easiest if picking up the trigger from the front of the vehicle.
