Results 1 to 10 of 10
Thread: Sticky deflator
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Sticky deflator
    I have a tyre deflator like the picture and the moving bits have a bad habit of sticking really badly; so hard that it is very difficult to turn or move by hand after it has remained unused for a while. And there is definitely no sand or other $hit in it.
    What is the best lube to use on these? I don't want to tear the O rings out or damage them with the wrong lube.
    W.A. (wandering aust)
    Graphite or Dry Silicone
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    Brissieboy (11th February 2019)
  5. #3
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Rub the threads with a pencil tip.
    As I lay there looking up, taking in the spectacular view that was the night sky and the multitude of stars I asked myself, where did my tent go?
  6. The Following User Says Thank You to Mc4by For This Useful Post:
  7. #4
    Quote Originally Posted by Mc4by View Post
    Good tip in most cases... but in this instance its not the thread (or at least never has been on mine)... 99% of teh time its the O rings on the slider and the spindle so the lubricant has to penetrate and also not hold dust, grit, sand etc.
  8. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Brissieboy (11th February 2019), Mc4by (10th February 2019)
  9. #5
    The master farter
    mudski's Avatar
    462 Post(s)
    Bitta spit and it will free up. Well mine does the same and that’s what I do lol.
  10. The Following 2 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (10th February 2019), Brissieboy (11th February 2019)
  11. #6
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Second for mudski or get a can of silicone spray.
  12. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
  13. #7
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Quote Originally Posted by 0-TJ-0 View Post
    Yep, that was the first thing I tried. Made it a little better but still way short of what I reckon it should be - it still binds when left for a while. I pulled it apart and thoroughly cleaned it and even polished the appropriate parts before using the silicon.
    Hesitant to use anything wet or greasy as it only attracts grit and dust, although I have seen someone use WD40 which did solve their immediate problem.
    Seems like this in not an uncommon issue.
    I do have some powdered graphite so might give that a go.
    Damn thing has had little use but is out of warranty. Might have to just pension it off and replace it. At around $20 it's not worth getting too upset over.
  14. #8
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by Brissieboy View Post
    you will more than likely find that all these deflators do it. Regardless of brand. I did use silicone spray in mine once. Helped for a while.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #9
    330 Post(s)
    Yes my ARB Deflator is the same. I did take the first one back as faulty but when the second was the same i figured it was a design flaw. Lubricate it if needed. I would not be too concerned about attracting dust as it is only out of its pouch periodically and not a bi deal. I was more concerned about causing the O Ring to break down depending on teh lube i use. I have not ever sprayed mine i just put up wth it. a little frustrating for sure.
  17. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  18. #10
    472 Post(s)
    I don’t even bother getting our wagons SuperCrapCentre one out on family trips anymore. Silly thing jams every second tyre. It’s just easier to pinch AB’s ARB one still going long time strong faultless
  19. The Following User Says Thank You to MB For This Useful Post:
