Results 1 to 8 of 8
Thread: 2nd battery
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    2nd battery
    since i want to make this as hard as possible.... has anyone fitted a battery where the jack is on a GQ.
    i have some ideas.... looking at a N70 battery half in there ( sorta along the car, not cross ways)
    anywho was hoping for some ideas or if anyone has fitted a battery how, before i bust out the angle grinder.
    yeah its gunna be tight, a box will be built over the wheel arch and to the door so you won't see it.
    581 Post(s)
    Bloody tight mate and you would need good ventilation.
    Not a bad spot though I guess, it will surely tick out though, go for it mate, get that grinder out...lol
    Jan 2015
    19 Post(s)
    the pillar is vented just above it and was thinking a gel if i could afford it
    yeah bout 5mm in it. measuring everything up for the box around and down the side.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    After I put in a set of drawers no way could I get access to that spot but if you get the right battery you can put them just about anywhere , I've got a spare under bonnet and another behind the cargo barrier both gel cel .
  6. #5
    581 Post(s)
    Quote Originally Posted by garett View Post
    I like the idea, keen if anyone else has done this?
  7. #6
    Jan 2015
    19 Post(s)
    ahh i don't have draws, and i carry big stuff in the back so draws are not going in. i've seen ppl mount 2 90ah in the gu's. i want to keep to a common size so its cheaper. the n70 i could swap with the main if i must.
    looks like i'm out with the grinder and welder
  8. #7
    Legendary
    194 Post(s)
    Garett, one of my configs had 2 x 100a/h batteries mounted in a ply box on each side of the rear cargo area directly above the wheel well. This gave me 400a/h capacity and it worked well. The batteries were circa 100mm wide and approx 350 high x 400 long - bit sketchy as was a while ago, but another option to save cutting a hole. These were deep cycle agms used as back up power supplies. You can still get them.
    This is the style but a bit bigger than the units I used.
    Or maybe look at the Optima range - small and powerful?
    http://www.ebay.com.au/itm/KICKASS-1...kAAOSw0hRZbvcR
  9. #8
    Jan 2015
    19 Post(s)
    i'll look into this, save me cutting holes. if i can find a battery the right size... would make this easier.
