Have an interest in being able to monitor Lambda (real time). Have only basic understanding...
Bought an UltraGauge EM Plus v1.2 in anticipation of accessing this parameter. Cannot access the gauge parameters (Lambda: requires voltage or current output of O2 wideband sensor). Parameter reads error. Eng CRD fitted 3" exhaust has a spare 1/4" BSP port in dump pipe. I did use the O2 port for my EGT pyro probe (spare port remaining).
Possible reason as why the gauge parameter is not accessible is that the sensor (Narrow or Wide) monitored by the ECU/ECM is not linked to the OBD-11 connector port.
Any suggestions how to access UltraGauge parameter for Lambda or even AFR command that is read by the ECM?
Or any proven method to monitor Lambda or AFR (real time)?
08 CRD Full NADS/ECU Remap. Thanks
