Results 1 to 6 of 6
Thread: EOI - 99 GU coil cab
    Beginner BushRanger7's Avatar
    Aug 2016
    PRICE: $EOI at this stage
    CONDITION: used, not heavily
    CONTACT: Andrew 0417 493 080
    COMMENTS: I'm thinking about selling my beloved truck after 9 years of blissfully exhaust tones.
    I could keep her for another 9 but the single cab isn't doing it for me any more. Plus the fuel is not in my favour given my current employment status 🙁
    Loaded up or unloaded she sits on about 16.8 litres /100km and running 15psi.
    I got her stock standard (minus an OME 2" HD lift that almost claimed 3 of my fillings on the first road trip). I got it off a fencing contractor who used it to cart a trailer of pine logs to his work site each week.
    Over the years I've added bits and pieces as finances allow with the aim of travelling Australia in it. That trip was completed this year (Melbourne, Echuca, Flinders Ranges, Innamincka, Birdsville, Winton, Townsville, Laura, Bamaga, Cape York, Weipa, Cairns, Normanton, Karumba, Katherine, Tennant Creek, Alice Springs, Adelaide, Bordertown and back to Melbourne)...
    Im now looking (don't laugh) at a dual cab Ranger or Amarock. Just not sure which one is going to hold up better in the bush as a go up to the high country a fair bit shooting and spend most of my time on the farm. It needs to be durable. I know nothing will compare to the rig I've got now but I simply can't keep forking out to feed her....
    SPECS:
    - TD42T
    - Turbo Engineering modified HT18 (6 months old)
    - 3 inch dump and high flow exhaust
    - factory twin tanks 75+85l
    - 2 inch lift with Koni 82 shocks, King springs and Firestone HD air bags
    - 265/75R16 BFG AT KO2 (with 17,000km and 80% tread) plus
    - 35" Maxxis bighorn (50% tread)
    - Red arc smart start solenoid, running a yellow top starter and blue top auxiliary AGM battery
    - Pro vent 200 oil catch can
    - factory winch bar
    - Nite stalker 55w HID 170's
    - Unidentified UHF
    - Low water coolant alarm
    - rebuilt Tigerz11 12,000lb winch with under bonnet isolator
    - Customer made roof rack with 2x 6" led bars on a 45°
    - on board thumper air compressor with 9lt alloy tank under tray with female QR coupling each side of the tray
    - customer made steel dog box with gas struts and fluoro light
    - cabin lined with 3mm insulation foam to reduce heat, cold and road noise
    - centre roof console with map pocket and UHF slot, also fitted BF falcon map lights
    - customer made (fully removable) canopy with a 1/3 width shelf, power bar with 3x 12v ports, 2x USB ports and inbuilt led strip lighting. Also includes the MSA drop down fridge slide to suit a 45l Engel.
    - Also on top of the canopy is a Tigerz11 rooftop tent with inbuilt light bar and 12v extension to canopy
    - 2x 8" led bars on chassis at rear for camping
    - kenwood head unit with remote and kicker 6" comp split door speakers
    - plus there's more I've probably forgotten.....
    Aug 2016
    Aug 2016
    Aug 2016
    Power bar inside canopy
  6. #5
    Aug 2016
    Back of the canopy with the drop down fridge slide, kitchenette with gas BBQ, 4.5l gas bottle and 20l water on a 12v pump
  7. #6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Bumped as last 4 posts went into moderation
  8. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    BushRanger7 (31st August 2016)
