31st December 2014, 11:15 AM
Auto oil
just asking my gu has clear or slightly yellow auto oil im going to put penrite semi synth in just any thoughts please
07 crd,,bridgestone 697lt, 2.75 buedesert ex,
SOLD theres a lot of my blood, sweat and money in that troll.
92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar
SOLD with a heavy heart but gone to a nice young fella
13 y62 the beast that burbles
31st December 2014 11:15 AM
31st December 2014, 12:21 PM
Needs changing the nissan matic d wasn't a bright red like most auto oils more a browny red, doesn't sound like you've got any water in there just needs a service just make sure the oil is compatible with the trans. It's been 10 years since i've played with any auto's and oils have come a long way.
The Following User Says Thank You to Sherro For This Useful Post:
kevin07 (31st December 2014)
31st December 2014, 12:31 PM
Went the Penrite path in the auto recently, first used semi-synthetic and was good for a bit then noticed I was getting some slippage on trans when releasing and then reapplying throttle but not all the time tho not to bad also gear change was a bit harsher, so decided to do it properly and took pan of and replaced strainer/filter and cleaned around magnet with new gasket, all looked good, replaced with Penrite Synthetic this time and slippage is gone and gear changes more smoother, was on special at repco and is not much dearer than semi synthetic anyway.
02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
The Following User Says Thank You to SG1 For This Useful Post:
31st December 2014, 12:55 PM
If you're moving to a different type of oil i.e. synthetic or even semi, best advice is to flush the lot. I bought a 20 lt drum of Nulon synthetic for $194 at Bursons.
John
The Following User Says Thank You to jff45 For This Useful Post:
31st December 2014, 05:34 PM
Sherro
thanks sherro the penrite specifically states nissan matic d yes and a service is overdue
The Following User Says Thank You to kevin07 For This Useful Post:
Sherro (2nd January 2015)
31st December 2014, 05:37 PM
SG1
thanks i will be changing the filter. i would go the full synth except i dont want to mix ill leave that one till i can get to wholesale automatics thanks. kev
