11th December 2014, 05:38 PM
Advanced
3lt power steering leak
Hey everyone,
I have a 2011 3lt common rail gu wagon, it has developed a leak on the power steering gear assembly. It seems to be leaking out of the bolt at the top of the box which I believe is some sort of adjustment for the power steering. Has anyone had his problem before? Ive tried to search the forum for similar problems but haven't had any luck. Is there a seal kit available for these? Hopefully I don't need to replace the gear ssembly?
2011 ST, Steel bulbar, warn winch, snorkel, arb rear bar, uhf, dual batteries, on board compressor, 2" OME suspension
11th December 2014 05:38 PM
23rd July 2016, 01:32 PM
Hello Dougy. Probably solved your interesting problem by now. Found your old post. Have just developed same problem on 1998 2.8l - probably same steering box. Not a big leak, but enough to make a lot of mess.
Usually just a reader, this is the first time I have posted anything.
If I solve it I'll post result.
Rustey
