Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Dual battery tray with sealed relay/fuse box.
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Hey guys this project was mid flight before I thought about putting it up. Not to mention I threw the battery tray together outa my scrap bin after I had consumed quite a few beers that afternoon.
    Relay fuse box will be completely sealed with electrical grommets. More pics tonight.
  2. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    mudnut (15th June 2013)
    Damn I wish I had the skills to do stuff like that! I need a dual battery tray made and it's not going to be cheap.
  5. #3
    .......... TPC's Avatar
    63 Post(s)
    That looks bloody good, you have all the gear to do that at home or do it at work?
  6. #4
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Nice work mate. Ye I made mine to. So simple.. I've sat mine on some rubber washers to remove some of the shock loading on the wheel arch as I've heard a few people who have had there's crack..
    Owner of
    Westy's Accessories
    Mar 2013
    Just in the home workshop, little arc welder, couple or grinders. Bench vice nothing special at all. I scored/cut the 3mm plate about 2mm deep in the bends to make it easy as to bend then just tacked the fold.
    I wish I took the time to go thru it step by step,
  8. #6
    Mar 2013
    I have to build another for a mate I'll get some templates off that and a step by step, honestly the hardest part is welding. Now days gas less migs are cheap and are dead easy to use for the beginner.
    Good idea on the rubber mounts, in a hurry must get to work.
  9. #7
    330 Post(s)
    Owner of
    Westy's Accessories
    Both the wheel arch inner guards are cracked on the GQ. About 100mm long cracks
  10. #8
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    That looks good man will keep my eye on this a so have been looking at making one or buying one
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  11. #9
    Mar 2013
    Hey mate is there any chance we could see some pics of the cracks? I have four solid mounting points the bracket has no movement in it at all. The only way I could see it cracking the inner guards if the tray it self was flexing or the battery tray was not sharing the load evenly over its fixing points.
    Guys Im going to draw the tray up on a4 paper and scan it so be a case of transferring the drawing over to metal and cutting the pieces out. Its a good simple project, start small thing big.
  12. #10
    330 Post(s)
    No probs mate. The tray you have made is fundmentally identical to the ARB tray I have in the GQ. Note also that the ARB tray also includes an extended top bar across top of the battery as part of the battery clamp and screws to the quarter panel to help with the weight of the battery.
