Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: A Guide on installing your own remote central locking in under 20 minutes
  1. #21
    Jun 2013
    Wishart Brisbane
    OK Wired as above. How do we now get the remotes to work. There's three buttons on the remote. How do we get it the remotes and the main unit talking to each other? I've got power in the remotes (coloured LED's flash). Thanks again in advance.
    Mark
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    there should be a learning button on the receiver module
  4. #23
    They should work out of the box. Mine did. But there is a learn button on teh module I think. If nothing happens when you press the button, maybe you have it wired incorrectly. Maybe.
  5. #24
    Jun 2013
    Wishart Brisbane
    Sorry. I've been a way a bit, and just getting back to this. Looks like I've got to look at the wiring again. I found what should be the learning button on the module. The wiring may be different, even though the wiring colours appeared to be right. Mine's a 2005 4.8 petrol on gas.
    Mark
  6. #25
    Jun 2013
    Wishart Brisbane
    OK. All working now. The wiring for a 2005 4.8 litre Patrol is as above, plus the Orange and Orange/Black go to ground.
    Mark
  7. #26
    thanks for this mark, ill be having a go later today!!! cheers for all the info!
  8. #27
    Jul 2015
    Adelaide
    Bit of a thread dig here but when replacing the module did you remove the old unit completely or still need some of the wires connected to that particular unit? Hopefully attempting it this weekend
  9. #28
    i ditched mine completely mate, havent looked back! sooooo much better!
  10. #29
    Jul 2015
    Adelaide
    About to start this but wanting to test that these wires are getting the signals needed. Would a test light on the lock and unlock signal wires as I lock/unlock the car with key show positive power through it?
  11. #30
    Jul 2015
    Adelaide
    Couldn't get the SCA kit to work, luckily I tested it before cutting into it's loom so returned it and got a 9500 winch instead
