Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Suggestions for Mods?
    Sep 2010
    Hi There, I have just recently purchased the 3.0 DDTI and have read with interest the comments, just cant get enough, Iam a fanatic about my vehilces, love fiddling with them. my previous car was a Landcruiser Vx, had not one problem with it, hopefully the Patrol comes up to my expectations as I have always wanted one as I feel there are only 2 true 4x4s, these being the Landcruiser and the Patrol
    Iam open to any suggestions on what mods I can do to my vehicle, I have been reading with interest the blocking of the EGR, can this be done with having to adjust anything ?.
    Iam South African but live in Uganda in East Africa
    Regards
    Lawrence
    581 Post(s)
    Moved your thread here Lawrence so people can find it better.
    Legendary
    As far as engine saver modifications go, your best bet is to read the reference document found here; http://www.nissanpatrol.com.au/forum...rence-Document.
    Blocking the EGR on its own will cause other problems, you will understand better after reading the reference document.
    Tony
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    Hi Lawrence,
    Personally, I believe that blocking the EGR on a ZD30 is a good move and helps to preserve the engine. It will increase your boost, so you may need to do something to bring the boost back down to an acceptable level so that you don’t have any limp mode issues. Also, you should consider fitting a catch can or better still a Provent 200 crankcase filter. This will stop the crankcase blowby gasses and oil from getting into your intake system where it will contaminate the MAF and intercooler.
    The other mods are to fit boost and EGT gauges to monitor the engine. There are many more that you can do and if you’re looking for performance as well as engine preservation, a performance chip, low restriction exhaust and lift pump are worth having.
    Good luck with the Patrol.
    Cheers,
    Chaz
  6. #5
    Oct 2010
    Quote Originally Posted by Chaz View Post
    Hi Lawrence,
    Excuse my ignorance here, but I would like some more info on the Catch Can.
    I have heard the term catch can mentioned a few times.
    I assume this prevents/collects oil vapour that normaly gets reintroduced into the air intake to be reintroduced into the engine for a cleaner exhaust.
    How hard is it to install, and where should it go?
    Cheers Mick
    Everyone makes mistakes, the trick is to make them when no-one is looking.
  7. #6
    581 Post(s)
    Hi Mick, this thread below explains the catch can in a lot more detail mate.
    http://www.nissanpatrol.com.au/forum...ighlight=catch
    If your still a bit lost or have any more questions mate, just ask.
  8. The Following User Says Thank You to AB For This Useful Post:
    molongmick (19th October 2010)
  9. #7
    Oct 2010
    Thanks for that AB
    Cheers Mick
  10. #8
    god pless you
  11. #9
    Patrolute4x4
    Guest
    Good thread mate
  12. #10
    Melbourne, VIC
    Great info, thanks
