that would be great, the reason I asked was roodogs on ebay have a filters kit for $90.
http://cgi.ebay.com.au/NISSAN-PATROL...item20ae763a4c
2.8TD GU, 0 - 100km/h in 2.8 minutes
Hi - How often should I replace the Fuel filter in the Rd28T?
I only use the genuine filters and the fuel I do every 20K or after I have done a trip away where I have picked up fuel from here and there and there and ...
Paul
Western Patrol Club member #27
2.8TD GU --> The Red Rocket
go to truck part supplies
Ive been using Sakura oil and fuel filters for years on japanese commerical vehicles without a problem around $10 for oil and $15 for fuel for most makes .I used to swear by fleet guard as well and still use these on yank engines. I agree with AB change fuel filter every 10 000 regardless and only fill up at high turnover service stations . oil every 5 000.
On the 2.8 the quickest and easiest method is to remove the fuel line after the filter (leading to the pump) press in the button on top ,put your finger over the outlet from the pump then release button. Remove finger , press button again, then keep repeating till diesel comes out then replace fuel line and give a couple more pumps. Usually only takes 15 to 20 pumps. hope this helps
Fill up the filter before installing. So you don't have to fill it with a lot pf pumping.
