9th September 2010, 10:44 PM
SUCH IS LIFE
9th September 2010 10:44 PM
10th September 2010, 10:51 PM
I'm on my third lot of Cooper STs. They are a great compromise between ATs and MTs. For the type of driving I do ATs are too tame and MTs are too aggressive. STs are just fine (as per baby bear).
10th September 2010, 11:00 PM
On my second set of Cooper's, first set was the STT's loved em but I thought I'd try the ST's this time, very happy with both types of tire and will definatly be buying another set, just not sure which one to get yet, but leaning towards the STT
Western Patrol Club member
GQ with 5.7 Gen 111 V8, Dual ARB airlockers, 33" Coopers, 9000lb Premier winch, Black Widow draws ![Cool](images/smilies/cool.png)
25th October 2010, 03:18 PM
I have just got my first set of coopers stt 32x11.5x15 and i am happy with them so far. they seem to handle good and they are not as loud on the road as I thought they would be
25th October 2010, 03:39 PM
Have the ATR and found them to be really good. Bought them because of the tread depth and reported long life and so far they are wearing well.
When I first got them they did tend to move around a bit if you chucked the Patrol into a corner too fast but either they have adapted to my driving or my driving has adapted to the tyre because I don't notice that now.
They are not the best on wet bitumen, they lose traction easily, but are not noisy at all. They do however pick up and hold the little rocks on the road. These work their way out and I regularly hear little rocks hitting the inner guards or bouncing along the road.
Haven't used them in serious mud or off road terrain, only sand and a few gravel hills, so can't comment on their off road ability.
Paul
P.S Not sure if I will use them, might try something different, will decide when the time comes (a long way off yet).
Western Patrol Club member #27
2.8TD GU --> The Red Rocket
![](image.php?s=c5fc2a61fa441561dae59b5444021e2b&u=51&type=sigpic&dateline=1308038239)
22nd January 2011, 10:35 AM
31 10.5 15 AT's
I have had these now for some time and i found them to be an extremely effective tyre, if you air them down off road. Running on an FJ60 cruiser at the time fairly heavy travelling over boulder and gravel it is imperative to air down correctly or they will chip and tear lugs, below 20psi I found worked for my situation. Sand driving towing a camper, camper down to around 12psi, vehicle varied between 18 on the high side to 15 on the low side of PSI and they responded excellent to the pressure drop. life of the Coopers is impressive, cant tell you milage, maybe the thief that stole the Blue 60 series could respond! Cost of the Cooper is not impressive at the time I purchased, but you get what you pay for. I would recommend them as I will be placing Coopers on the GQ for next tyre change. note, old AT pattern has changed I believe.
17th March 2011, 08:08 PM
26th May 2011, 06:46 PM
#8
Enjoying the trips
I had a set ot ST's on a '05 hilux I had, the rears wore pretty badly on the Simpson trip, most of the damage done around the Moomba Gas Fields as the tracks were well graded with sharp stones that the fronts spat into or stood up for the rears to cop it. Got over 65000klm with 40% left on the fronts but 15-20% on the rears. Allways rotated them at 5000klm to.
Then got a set of STT's what a difference in off road grip, fantastic, got about 70000klm from them, now worn them out on the Patrol.
As they are worn I have been pushing them a bit harder on a sharp rocky climbs and have ripped a lug off one and staked the side wall on another recently and are being replaced.
Went for MTZ from Micky Thompson only reason was the side biters are massive compared to the Coopers.
Same price and exact same measurements and have a feeling the carcases are identical.
Coopers are good and would use them again, never had a flat in all that driving as well.
26th May 2011, 08:15 PM
#9
We put cooper S/T's on the GU and are very happy with them. Done mostly bitty driving (as we live so far from anything!) and sand driving and they have never let us down. Rotate every 5000km and get a wheel alignment every 10,000 just to get the absolute best out of them. Would buy them again and recommend them.
GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
Front and Rear "
LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
http://www.nissanpatrol.com.au/forum...screen-Sticker
27th May 2011, 10:27 AM
#10
Patrol Guru
33x15 Discoverer STT. This is my current and 1st Cooper set. About 60k km on the clock, rotate and balanced every 10k km. Great tires even on a paved road..love them very much. Looks great too. Definetely would recommend them
