26th May 2011, 01:40 PM
#11
Thanks for all the comments guys,.
I use a 70W which is quite viscous and not a problem, not super quick but okay and at least your not lying under the car dripping oil.
If concerned you could always put the pump in a bucket of hot / boiling water fro few minutes which will heat the oil and reduce the viscosity.
It is all done with air pressure so there are no moving parts to be effected by viscosity, only the friction losses in the hoses will increase with thicker oils.
p.s. High viscosity = Thick Low viscosity = Thin / runny.
Cheers,
Richard B.
26th May 2011 01:40 PM
31st May 2011, 08:20 PM
#12
Hi,
That is a great idea, wish I had seen it earlier, I spent ages under the car filling it up
Thanks for the info
John
31st May 2011, 10:15 PM
#13
now brake bleeder what a bloody good idea, beats winding down a compressor.
Tim
Getting Older Is Unavoidable, Growing Up Is Optional!![Coffeetime](images/smilies/coffeetime.gif)
20th July 2011, 06:00 PM
#14
a member of the menagerie
I wonder how you'd go using one of these,
It'd put the oil in pretty quick I reckon
Quikspray Unit
Seriously though bloody good idea
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me ![](image.php?s=6653c3f66dd945d7ddf49c166fa8c922&u=3539&type=sigpic&dateline=1357444542)
20th July 2011, 07:00 PM
#15
23rd July 2011, 04:32 PM
#16
great idea, found a sprayer during street clean up, will look at doing the mods, am sick of transfering oil into small bottles.
Zoro
29th July 2011, 01:49 AM
#17
You got me sold, off to Bunnings i go, might even buy one to spray the weeds with. " Dam fine idea "
2.8Lt might be slow , but so was the Turtle ?.
18th February 2012, 06:42 AM
#18
great idea ,, easy and cheap ,, i will make one for my self thanks
18th February 2012, 08:06 AM
#19
Enjoying the trips
Use a weed sprayer as well, makes it really easy.
And less mess
18th February 2012, 12:46 PM
#20
Smart like tractor
the trick with thick oils is to fill a bucket or esky with hot water and put the unopened container of oil in let it heat up for a while ther oil will be thinner and easier to work with
96 GQ coil/Cab
08 G6eT
![](image.php?s=6653c3f66dd945d7ddf49c166fa8c922&u=1281&type=sigpic&dateline=1483248064)
