Results 1 to 6 of 6
Thread: Any savvy advice on belt replacement (A/C, Alt & P. Steering) would be highly welcome
    Feb 2012
    Hi Guys,
    Just trying to change all the belts in my TB45. From a theoretic point of view it seems affordable, but I'm pretty sure there are a lot of tips and tricks to be aware of.
    Any advise from your side would be very welcome. Apart of being all of them very worn, the decision of change them comes from a weird sound coming from the A/C one. If I spray some silicon on it the sound disappears, but after less than a minute it comes up again.
    Do you think it would be necessary to replace also the A/C pulley?
    Any tip to properly tension all the belts?
    Thanks in advance,
    Try new belts,
    if the belt sits a few MM's down into the pulley then it's probably best to get new pulleys for optimum operation and life from your new belts. But it is not vital.
    Your new belts will still work on a worn v-belt pulley.
    Owner of
    Westy's Accessories
    Most belts when tensioned right is approx 10mm - 15mm deflection, Ring Gary or email nizzbits great prices on OE parts.
    Air con belt probably an arm and a leg to buy if similar to tojo's, wait till it breaks, if you can live without it for a day or too IMO
    Hardcore
    central coast nsw
    Yes,
    keep the sleeves off new belts for future size reference.
    even put old belts in them and put under back seat in case.
    Check idler bearing.
    Water pump is ok ?.
    Fan viscus clutch is ok ?.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    Feb 2012
    Thanks for all your suggestions guys,
    Regards,
    May 2024
    I need to follow this thread as I'm about to replace an all soft Alt and ps belt!
