10G (10th May 2024), AB (6th May 2024), BigRAWesty (18th May 2024), MudRunnerTD (6th May 2024), mudski (6th May 2024), Plasnart (5th May 2024), Stropp (5th May 2024)
Bhahahahaha
Just bought a Brake light switch for the Y62 as they are a known failure point and if it fails you can not start the car. While i was there a pair of inner and outer CV boots for the front and the back of the Y62 and 1 Bush for the control arms. All into the spares kit.
well, injector cleaner (petrol), llm spheerol grease for grease gun and start ya bastard.
got some work on old mowers and old utes coming up.
got a new foglight for the 'trol.
4t jack stands and a set of deep 1/2" drive sockets
Bought a new h/d Sutton Tapping wrench, finally destroyed 3 wrenches today in fast succession on the tapped holes of the antenna mount - poor man pays twice comes to mind! Also bought a set of the over-center canopy body kits to lock the canopy to the tray. There are bolts at the front and rear however the fronts were in shear, so after a close examination found I had built a set-up that was very difficult to impossible to replicate the rear bolts in tension.
Stropp (13th May 2024)
Jack stands arrived from Total Tools today - got the bellow from the front door - 'ITS YOURS AGAIN< TOO HEAVY, YOU SORT IT OUT - door slams - yep they are beauties, along with the magnetic deep throat 1/2" drive sockets - gotta love internet shopping!
This brute arrived today. The original surviving HD tapping wrench is at the bottom. I like the extra leverage and everything is so much bigger and gruntier.
MudRunnerTD (17th May 2024), Stropp (18th May 2024)
Bought a 3/8 twist handle socket bar. Mostly for the bike but will likely be handy for lots of things.
I Sold a Testicle and bought the Coil Delete Rear Airbag system for the 62 today, will have it by Next weekend. Then need to fit it then get the car over to Hastings for a few days for the front lift and Engineering for a 4000kg GVM Upgrade. I cant do the front lift at home as the HBMC Suspension system needs specialist equipment to bleed and re-charge the Hydraulics. Exciting times.
BigRAWesty (18th May 2024), BrazilianY60 (18th May 2024), Cremulator (18th May 2024), jay see (18th May 2024), MB (17th May 2024), PeeBee (18th May 2024), Plasnart (18th May 2024), Rossco (12th June 2024), Stropp (18th May 2024), Touses (18th May 2024)
