Page 55 of 57 FirstFirst ... 5455354555657 LastLast
Results 541 to 550 of 563
  1. #541
    475 Post(s)
    Looking Great Philstar
    Only my Nuffy opinion for weight saving Da Beaut Beast Brother
    There in theory could be another way instead of utilising full length leftover checker plate steel plates both top and bottom (totally understand your forward HC driving snagging smooth deflection log logic)
    I believe/hope leaving your new sliders undersides open for cleaning/rust purposes could benefit from this wacky theory
    Weld the beaut kit fully up, yes, weld atop leftover checker plate
    In theory, again, simply weld in short flat bars say 30mm wide x say 3mm thick x slider width underneath @ say 45 degree deflection bars/plates at every round RHS intersection:
    Best MB AutoCad/Solidworks capabilities
    EDIT: Apologies Philstar, meant CHS pipe
    Apr 2021
    Brazil
    Or both sides to account for when he is reversing.
  4. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (30th April 2024), PeeBee (30th April 2024)
  5. #543
    196 Post(s)
    Thanks Mark, yes that will work also, sealing it up has some issues if the welds crack or I dont do a good job on the checkerplate. I dont need the weight as you mention. Back at the computer again after 4 days off, so into the soup for now. Looking at some troubleshooting on the interchiller pump, might be voltage related - going to try with a very locat battery and with luck it starts pumping. Can you believe there is no after sales support by way of seals or pump kits for a $1000 pump - answer coming back is bin it and buy another one - its run maybe 30 hrs max. Appalling.
  7. #544
    196 Post(s)
    Another good optimisation, thanks.
  9. #545
    196 Post(s)
    Sorted the Interchiller pump out today, conductor size and volt drop. Rigged up a 200a/hr lithium and short heavy cables, fired the pump up, guaranteed 40lpm by the flowmeter thru the system, happy days, just needs some more heavy duty wiring and relay to resolve completely - one more bee sting sorted. Happy happy days I can assure you.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (1st May 2024), MB (30th April 2024)
  11. #546
    475 Post(s)
    Perfect Point BZ Brother
    Different Cultures I’m assuming, uz Aussie’s only ever go forward, never backwards….unless we are suckered into LandCrab Tradie Ute Territory’s
  12. The Following 3 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (1st May 2024), Cremulator (1st May 2024), PeeBee (30th April 2024)
  13. #547
    Apr 2021
    Brazil
    LOL, gold mate!
    Usually you only think of going backwards is when you are already stuck, LOL.
  14. #548
    196 Post(s)
    Interchiller wiring finally resolved, bigger cables, big relay, runs beautifully, see if it delivers, swapping out the water or glycol this arvo.
  15. #549
    196 Post(s)
    Looks like I am up for a new or remodelled interchiller tank. The location of the tank outlet was deliberately put at 1/3 off the bottom of the tank to reduce any drawdown of crap into the pump inlet. I am now finding the available head above the tank outlet is absolutely zero tolerance between 40lpm lpm flow and 12-18lpm fluctuating if the water level drop by as little as 15mm. I have been looking at flow meters and current draw and temperatures achieved and they are all over the place.
    Anyway its not a massive issue in the scheme of things, either make a new tank or whip the existing out and add a lower outlet - just time once again.
    So with the flow at 40lpm and the full divert of the water flow thru the interchiller(gas/water heat exchanger) I am getting a good heat reduction in the inlet air post the w2A unit in the inlet manifold. I am able to wash off up to 60 degC from the inlet air post compression, which is great. Makes a big difference in 40 degC days to cruising egt's. Still not great for low range crawling stuff , but the water spray bar on the radiator works very well to keep those blips in check with minimal water consumption.
  16. The Following User Says Thank You to PeeBee For This Useful Post:
    mudnut (2nd May 2024)
  17. #550
    No just the packing, all loose, tacked them together today, took 20 mins, after spending 7 hrs fighting with the interchiller pump, that has now been 100% confirmed as dead - pumped at 40lpm with a forced inlet and shot water across the road maybe 6m, but hooked up with a hose system thru the heat exchangers and zero - reckon the seals on the impellar are shot - waiting to hear if a kit is avail - hope so, pump was close to $1000 at the time.Attachment 88002
    Ghee mate! I reckon that bloke who made those for you was scared of the dark! There is a few extra noggins in there! I see Heavy...Is it Tube or Pipe? I smooth plated the underside so they slider over mud etc and the checker doesnt jag on any edges. Checka on top, smooth on the bottom.
