18th January 2024, 07:06 AM
#10421
pollenface
flushed my radiator until it was clean
Probably something I should do while my Patrol is apart in the garage getting some love.
18th January 2024 07:06 AM
22nd January 2024, 11:34 PM
#10422
The Following 3 Users Say Thank You to MB For This Useful Post:
Cremulator (23rd January 2024), growler2058 (25th January 2024), jay see (25th January 2024)
23rd January 2024, 04:48 AM
#10423
The Following User Says Thank You to BrazilianY60 For This Useful Post:
24th January 2024, 08:43 PM
#10424
The Following 2 Users Say Thank You to MB For This Useful Post:
BrazilianY60 (24th January 2024), growler2058 (25th January 2024)
24th February 2024, 05:53 PM
#10425
24th February 2024, 09:07 PM
#10426
Bit of an odd one. I have done a body swap and chop on the GQ. The original car was a 1997 model and I have used that interior. The donor was a 1991 body, that was chopped. Today I started the final prep before driving it out of the shed and getting ready for VASS engineering. I tried to get the rear seats to latch onto the floor latches, using the 1997 back seats and the 1997 catches. They required the mounting holes slotted to get the latch to land in the middle of the seat catch. All looking good except the seat catch wont receive the latch on the floor. I stuffed around for 6 hrs with this today, tried all sorts of packing and optimisation, had @AB and @MB have a look, baffling. I am fabricating a floor stiffener tomorrow morning as a packer to go right across the rear floor and pick up the two floor catches i case the floor is flexing.
Has anyone come across this before? the 1991 floor catch is way too short to operat1991 in front 1997 in rear.jpge and too low in height to pick up the seat catch. Couple of pics for clarity. I need a solution or the car wont pass the inspection.
24th February 2024, 09:15 PM
#10427
Breadmaker Shaker
Fck cars pb. When you think you’ve been through all they can dish out, they find another way to fck with your mental well-being. Honestly to come down to this mate you are in my thoughts.
![](image.php?s=1d4b51488c3797b7e09681199e07e833&u=115&type=sigpic&dateline=1651651487)
The Following User Says Thank You to Plasnart For This Useful Post:
PeeBee (24th February 2024)
24th February 2024, 09:20 PM
#10428
Plasnart
Thanks Plassy, its fighting me right to the end. Spending 6 hours solid trying to think and react without a positive outcome, its exhausting, far worse that doing the physical. The journey has had its moments that is for sure. the end product will be good, but there are still hurdles to get over. Its been 2 yrs on this, far too long and more than enough patience expended by @MB to let this continue.
25th February 2024, 08:15 AM
#10429
Can you get an inspection camera under there to see where it doesn't connect?
PeeBee (25th February 2024)
25th February 2024, 07:37 PM
#10430
ok, would you believe there are 3 versions of the same catch? Yes, well there is and I have one pair of each. I found the third set this morning after stewing over the impossibility of the catch not fitting in the set clasp. I swapped the third set out and the seats went 'click, done. Happy days.Catches.jpg
The third set is made from a smaller diameter rod, so it allowed the catch to close.
The Following 4 Users Say Thank You to PeeBee For This Useful Post:
BigRAWesty (28th February 2024), BrazilianY60 (26th February 2024), Cremulator (25th February 2024), mudnut (25th February 2024)
