Results 1 to 6 of 6
Thread: ZD30 improvement
    Advanced powkers's Avatar
    Bydgoszcz, Poland
    ZD30 improvement
    Hi Guys,
    Here in Europe we are mostly swapping ZD30 to M52 or OM606... I want to avoid that for simplification reasons.
    I have opportunity to buy blown ZD30 for like bottle of vodka and I thought if you have "idiot proof" kit for rebuild and improve ZD30?
    If yes could you please share any links to kit recommended by you + any info if such modification will allow me to safely increase power a bit (170-180 HP).
    Thanks in advance!
    PS. I'm sure there are plenty of such discussions already happened here on the forum so any links I also appreciate.
    Cheers!!!
    Don't waste your Vodka on an engine built for detonation. Unless is Russian Vodka, then tip it down the drain. Especially if its the Direct Injection engine, Common Rail, AKA Common Fail, are a much better choice. I've read good words about a Benz engine swap, albeit a bit of a pain to do so.
    Bydgoszcz, Poland
    Thanks!
    For me problem with swap is price (to make it good especially to work with automatic gearbox), other is complexity of solution. Most of people after swap are happy for performance and petrol consumption but they are having constantly problems with small annoying issues. I wan to avoid that.... but basing on what you are writing those ceramic pistols and "custom ZD30 rebuild kits" doesn't solve this engine problems :/
    Not good I thought I can have easy solution
    BTW: Vodka is cheap here
    The only way to solve ZD engine problems is to swap it out. Been there done that....
    Apr 2021
    Brazil
    Dumb question here... I watch a lot of aussie YouTube channels (Skid Factory for one) where they swap engines and put Haltech ECUs in it. One of the ZD30 versions is electronic, isn't it? No aftermarket ECU for such things? Like to drop all emissions BS and focus in EGT, boost and A/F ratio?
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    just the usual, intake manifold removal and clean, catchcan, manual boost control, EGR blanking, fully welded intercooler, 3" exhaust, dyno tune,
    2008 CRD Auto Wagon
