Results 1 to 6 of 6
Thread: Removing carpet underlay
    197 Post(s)
    I have jing pinged my floor and a second layer of closed cell foam, so want to remove the old hairy underlay off the back of the carpet - it has a vinyl layer between the carpet and underlay.IMG_1312.jpg
    Ballarat, Vic
    176 Post(s)
    Jing pinged?
    197 Post(s)
    Its an acoustic deadener and also has some limited thermal ability. Its a 'weighted vinyl layer that can be moulded and stretched to the contour of the floor, wall, roof of a vehicle. I have done the roof lining, rear wall, floor, firewall and all doors, then laid a further layer of different insulation that wont absorb water either. Jing Ping wont absorb water. the fluffy stuff under the carpet is a bugger for that and can takes ages to dry out if it does get wet.
    Cuppa (11th October 2023)
    331 Post(s)
    I reckon the smooth face you see is the underside of the carpet and you should be able to separate.
    Apr 2021
    Brazil
    3 Post(s)
    Jing pinged?
    Its an alternative brand (Jing Ping) to the famous aussie one called Car Builders, american one called Dynamat, etc.
  7. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cuppa (11th October 2023), PeeBee (9th October 2023)
    197 Post(s)
    I attacked the carpet by first removing what I could by hand then using a 4" angle grinder with a 40 grit fan wheel, simply perfect - stripped it off the entire underside in under 5 mins. I could go back and give it a follow up, but its down to the vinyl, so might leave it there.
  9. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (10th October 2023), Cuppa (11th October 2023), MudRunnerTD (10th October 2023), rossco3775 (10th October 2023)
