Phuck I reckon I can do this one! Is there a poll anywhere?
BigRAWesty (7th August 2023), Stropp (4th August 2023), Winnie (8th August 2023)
growler2058 (7th August 2023), Stropp (4th August 2023)
Love ya Dazz but they are welcome here to chat just like Amy does here for our forum trips.
Same as you Stropp mate, who cares what cars anyone has these days, sign up here, chat guys?
Don’t let the the big boys win.
Or else we’ll end up like this…
http://www.nissanpatrol.com.au/forum...een-Turned-Off
AB (8th August 2023), BigRAWesty (17th August 2023), Rossco (8th August 2023), Stropp (12th August 2023), Winnie (8th August 2023)
BigRAWesty (17th August 2023), growler2058 (23rd August 2023), Stropp (12th August 2023)
AB (9th August 2023), BrazilianY60 (9th August 2023), Rossco (9th August 2023)
growler2058 (10th August 2023), Stropp (12th August 2023)
I personally think its wheel bearing tightness. I have not had the death wobbles for years, after having it and replacing everything. The last resort was put new stub axles in as I noticed a small step where the inner wheel bearing sat, right against where the hub seal ran. after I replaced the stub axles all was good. This was some 8 years ago I think. The wobbles were recently slowly coming back, I jacked up the front and both wheels felt good, I gave both wheel bearings an extra one only notch to tighten them up. All wobbles were gone.
So my theory is the wheel bearings need to be slightly tighter than you think, especially if your running larger tyres.
But. If you need help with anything. Shout out. If I'm able, I'll help.
Yeah I reckon check stub axles, I put some new ones on mine recently only so many years of use and more recently abuse (mud mud mud) they will take. Obvious but check drag link and tie rod ends, panhard bushes, someone also mentioned new rotors fixed it for them so that could be something to keep in mind if all else fails. .
AB (10th August 2023), growler2058 (10th August 2023), mudski (10th August 2023), Stropp (12th August 2023)
