I'm not a car doctor but preparation for a higher clearance rear bar I performed a Rear Quateroscopy as high as l could go.
I covered the area with black Sikaflex 227.
BrazilianY60 (13th June 2023), Cremulator (12th June 2023), MB (12th June 2023), mudnut (12th June 2023), mudski (13th June 2023), Plasnart (12th June 2023), Touses (12th June 2023)
Not a doctor? You could bloody eat off those boots! Do you have an actual work pair and then a pair for when you just wanna take photos? Nice work. Assuming the rear bar will.be produced in house also? How did you install the weepers to help with water ingress?
Trolatron (12th June 2023)
[QUOTE=rusty_nail;839910]Not a doctor? You could bloody eat off those boots! Do you have an actual work pair and then a pair for when you just wanna take photos? Nice work. Assuming the rear bar will.be produced in house also? How did you install the weepers to help with water ingress?]
Haha yes Nic id only had them boots about a week. I have no idea why but there was already a thick 40mm plastic tube running up inside the old quatre panel which goes right up to the nearly the window with all the wires running inside it. I sealed up the opening best l could and if any water did get in there it would have to be window deep to get inside the car. Rear bar pics coming up next.
rusty_nail (12th June 2023)
Ah, here is our old friend bptrick posting a link in the full stop at the end of that garbled mess.
growler2058 (13th June 2023)
First time I see a quarter chop on a GU. All the ones I´ve seen so far are on GQs.
Most people have a single flat bracket onto the front body mount bracket but l like to go overkill.
BrazilianY60 (13th June 2023), Cremulator (13th June 2023), MB (14th June 2023)
Cremulator (13th June 2023), Trolatron (13th June 2023)
Well done mate. Top notch work done. I widh my welding was neat like that.
this is how far the rear bar has progressed so far. I still have to finish the swing arms and decide how I want them set up.
I will get it powder coated when its finished, haven't decided to go black or white yet.
BrazilianY60 (13th June 2023), Cremulator (13th June 2023), MB (14th June 2023), mudski (13th September 2023), Plasnart (14th June 2023)
