20th May 2023, 11:26 PM
Can I drill here
So I finally made a start on the battery terminals. I was able to take off the negative terminal and make it fit to the new terminal block. The positive that is circled is part of the wiring loom and will be not come of the car. I want to cut along the dotted line and drill where the green dot is. Can I hit it with a angle grinder and drill without blowing everything up..
20th May 2023 11:26 PM
21st May 2023, 06:32 AM
with the negative disconnected i'd do it with a hacksaw, or even a pair of av-shear/tinsnips.
copper will gall in a grind disc and there's too much potential to slip or grab with a grinder and do damage.
1989 LWB 5-Seat, TD42
The Following 2 Users Say Thank You to mihit For This Useful Post:
jay see (21st May 2023), PeeBee (21st May 2023)
21st May 2023, 09:32 AM
The Following User Says Thank You to Cremulator For This Useful Post:
21st May 2023, 11:42 AM
I did the negative with the grinder in a vice. While it's off I think I'll drill the new hole while connected and see how I go holding it up and using a slitting disk..
The Following User Says Thank You to jay see For This Useful Post:
rusty_nail (21st May 2023)
