finally finished off some tidy up & 'make it better' work under the bonnet.
fitted a battery isolator switch, reran some cabling, repaired an SBI12, removed & cleaned the catch can, cleaned around the catch can area, fabb'd up a new pre fuel filter holder & fitted same (could've done a motor swap in less time), removed dead 2nd battery, removed gunk, repaired broken bits n pieces, tightened this n that.
started on the 3rd battery electrics yesterday, almost finished that, just making it a little more robust and more neaterer.
New fuel pre filter holder pre painting...
