Results 1 to 10 of 10
Thread: Real life fuel consumption
    Aug 2011
    River Heads Q
    4 Post(s)
    Hi all and merry Christmas
    Planning some trips next year before I get to old and decrepit.
    Looking for actual fuel consumption for 4.2TDi on different tracks. The worst I have recorded is 22 lt per 100k in the loose sand on Fraser when tides were against us and best in present set up is about 13lt per 100k when touring.
    Would like to do Canning but from east coast it is a big ask. I would need to upgrade either or both fuel tanks to do the approx 1000klm between fuel stops so a considerable expense for a single trip so will probable do something shorter like Tannami and then back across the Gulf to Qld and down to Carnarvon George area.
    Did Gunbarrel back in 2016 but cannot find diary with details but from memory it was not too bad as there was no sand but just slow going.
    Will be leaving Avalon airshow early March next year and heading north or west or both so any help with actual figures would help.
    cheers
    Peter
    174 Post(s)
    We have recorded our fuel consumption for several years travelling a wide variety of terrain. Most but not all towing our Tvan. All up weight of car + Tvan fully loaded is around the 5tonne mark, which obviously goes down as supplies, fuel & water get used. 265/75R16 tyres
    Best was a fraction over 12L/100. Worst was 20.5 L/100. Average over two periods comprising a total of around 5 years (Stuffed up with the app & had to start from scratch again) showed almost identical averages - First two years & second 3 Years - 15.6L /100 within 0.1 litre. I have a fairly light right foot - often happy to poodle along at 80 or a fair bit slower on tracks. It makes a difference! If we were towing on the CSR I would be allowing for 25L/100. If car only probably 20 or 21.
    Our fuel tanks hold 180 litres, (95 & 85) would normally get us well over 1000kms, but for the Canning I'd be carrying 4 jerries in the car too & feel fairly confident that'd give us a reasonable safety margin.
    I think we've decided to leave the Canning until we have a truck based camper. Towing, although do-able sounds like hard work & less enjoyable. Without the Tvan we'd be carrying a tent & I think we're already too decrepit to consider that any more!
  4. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    mihit (22nd December 2022), Wizard52 (22nd December 2022)
    175 Post(s)
    I've loosely been doing my consumption over the years.
    2005 td42ti , average around town is 14-15 or there abouts. Sitting on 33" all terrains. No towing.
    Sent from my Pixel 6 using Tapatalk
  6. The Following User Says Thank You to Hodge For This Useful Post:
  7. #4
    465 Post(s)
    This my one and only time I recorded fuel consumption.
    This was towing my Jayco Off-road Swan and loaded to the hilt and towing in high 30 degree heat for the first half.
    GUII And a slightly tickled TD42.
    48ltrs 262.5ks = 18.32 Bairnsdale
    75ltrs 644.4K 382k = 19.63 Bright
    80ltrs 1122k 478k = 16.74L/100 My Beauty
    73ltrs 1604k 482k = 15.5L/100 Myrtleford
  9. #5
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    https://www.fuelly.com/car/nissan/patrol
    I have made a point to check a few times. Between 12-18 lt/100km from memory. All run 33" A/T or M/T. Manual, stock diffs.
    Depending on the season my driving probably averages to 60%seal 30% gravel/metal and 10% mud/sand. Wagons usually loaded to 2.5T with tools and dogs and shit. Occasionally towing <3.5T
    1989 LWB 5-Seat, TD42
  10. The Following User Says Thank You to mihit For This Useful Post:
  11. #6
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
  12. The Following User Says Thank You to mihit For This Useful Post:
  13. #7
    Aug 2011
    River Heads Q
    4 Post(s)
    Hi Cuppa
    I would say our main rear tank would take a bit more than 95lt (probably 98/100lt) and the sub tank takes about 84/85 depending on where we fill up.
    With my present set up (Rhino camper which reminds me I have to update details on the forum) I would have to carry extra fuel inside so not ideal but doable in need.
  14. #8
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by mihit View Post
    Yep I already have one of them.
  15. #9
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Quote Originally Posted by Wizard52 View Post
    I get about 8 across the back of the wagon... and they could serve double duty as flotation devices, water jerries (with a plastic bag liner)... land anchors... not that I've ever needed any of that functionality, but on the day I do I'll be stoked
  16. #10
    Beginner Adebayor Bloomfield's Avatar
    Jan 2023
    Toronto
    If you're in the market for a sports car, a repairable Chevrolet Corvette bought on a car auction might be an excellent option for you. Recently, a repairable Chevrolet Corvette from the year of 2006 was sold on a car auction site abetter.bid for 5900 dollars. While the car might need some repairs, the fuel consumption of a Chevrolet Corvette is relatively low compared to other sports cars. According to the official Chevrolet website, the 2006 Chevrolet Corvette gets an estimated 18 miles per gallon (MPG) in the city and 26 MPG on the highway. That means that if you're driving mostly on the highway, you can expect to get around 400 miles on a full tank of gas. However, it's important to note that these are just estimates and your actual fuel consumption may vary depending on your driving style and conditions. Additionally, it's worth mentioning that the Corvette is a powerful car with a V8 engine, so if you drive aggressively or take advantage of the car's power, you can expect your fuel consumption to be higher.
