7th November 2022, 04:46 PM
#11
Currently in coffin bay for 2 days, exploring tomorrow and oyster tasting then off to port Lincoln 33374674-87C8-4932-90FD-88A23315E861.jpeg88E64EAA-A63A-4E21-A10B-A548F56DD2A8.jpeg
The Following 7 Users Say Thank You to Stropp For This Useful Post:
BrazilianY60 (8th November 2022), jack (8th November 2022), MB (8th November 2022), mudnut (7th November 2022), mudski (8th November 2022), pearcey (7th November 2022), Touses (8th November 2022)
7th November 2022 04:46 PM
8th November 2022, 09:00 PM
#12
Hardcore
Jack
The Following 2 Users Say Thank You to jack For This Useful Post:
MB (9th November 2022), Stropp (9th November 2022)
9th November 2022, 07:56 PM
#13
jack
Hope the oysters worked Stropp
![Wink](images/smilies/wink.png)
I didn’t get to jack, off I went to sleep 😜
The Following 4 Users Say Thank You to Stropp For This Useful Post:
jack (10th November 2022), MB (9th November 2022), pearcey (10th November 2022), Plasnart (10th November 2022)
10th November 2022, 07:56 PM
#14
So having dramas with the tcv connection, I’ve had this drama previously and ufi in Perth said they just cleaned the connection and tightened the connectors and it was fine, it’s happened again so I took it to a mob in port Lincoln and they said the cleaned it and the fittings were tight. I drove off and as normal the motor started to rattle and the check engine light came on again, took it back but they said next week before they could look again anyway drove to Cowell and on the ferry tomorrow to wallaroo to save driving an extra 350k, hopefully I can get it fixed in Kadina
Ps bad connection causes the timing to go full advance apparently and motor gets a good rattle up and the engine light flashes
The Following 3 Users Say Thank You to Stropp For This Useful Post:
Cremulator (11th November 2022), MB (12th November 2022), mudnut (11th November 2022)
10th November 2022, 08:53 PM
#15
Hardcore
Stropp
Punctuation is important Stropp.
Especially when your name is Jack.
ie: Can you help your uncle Jack, off a horse.
Can you help your uncle Jack off a horse.
Jack
The Following 3 Users Say Thank You to jack For This Useful Post:
MB (12th November 2022), mudnut (11th November 2022), Stropp (11th November 2022)
10th November 2022, 09:14 PM
#16
Breadmaker Shaker
jack
Yes and yes. And he drove a Commer but didn't know where to park it!
![](image.php?s=4d34a9529f663d2439cfce85cefdb472&u=115&type=sigpic&dateline=1651651487)
The Following 4 Users Say Thank You to Plasnart For This Useful Post:
jack (10th November 2022), MB (12th November 2022), mudnut (11th November 2022), Stropp (11th November 2022)
11th November 2022, 01:03 PM
#17
jack
Aah you see what I did there 🤣🤣
The Following 2 Users Say Thank You to Stropp For This Useful Post:
jack (11th November 2022), MB (12th November 2022)
12th November 2022, 01:25 PM
#18
Stropp
So having dramas with the tcv connection, I’ve had this drama previously and ufi in Perth said they just cleaned the connection and tightened the connectors and it was fine, it’s happened again so I took it to a mob in port Lincoln and they said the cleaned it and the fittings were tight. I drove off and as normal the motor started to rattle and the check engine light came on again, took it back but they said next week before they could look again�� anyway drove to Cowell and on the ferry tomorrow to wallaroo to save driving an extra 350k, hopefully I can get it fixed in Kadina
Ok so the brother in law’s neighbor and his some, both mechanics came over and found a bad soldered joint with a broken wire when ufi replaced the tcv plug, installed a duetche plug and walla patrol is running perfectly again 👌
MB (12th November 2022), mudnut (12th November 2022), MudRunnerTD (12th November 2022), pearcey (12th November 2022), Plasnart (12th November 2022), Winnie (12th November 2022), Woof (12th November 2022)
