6th September 2022, 11:37 PM
Any particular reason for the adjustable panhard bars be tapered on one and only with the other end fixed/welded? The way I imagine, if you build it tapered both ends (so with an "floating" adjustable section) you could adjust the track position without taking the panhard chassis end out, which is a pain to put back when misaligned.
overlandh1978
The Following User Says Thank You to BrazilianY60 For This Useful Post:
MB TD42 (12th November 2022)
6th September 2022 11:37 PM
7th September 2022, 01:20 PM
That's just how they came. I've had issues with double adjustable bars coming loose before so I'm good with these ones
The Following 2 Users Say Thank You to overlandh1978 For This Useful Post:
BrazilianY60 (8th September 2022), MB (4th June 2023)
8th September 2022, 02:44 AM
Interesting to know, as I am just about to turn mine into adjustables. If comming lolse is a common issue, I may have to change my plans and make them like yours.
11th September 2022, 12:00 PM
fwiw i run double-end adjustable tie rod and drag links (no lift) and have no issues.
1989 LWB 5-Seat, TD42
11th September 2022, 12:20 PM
I'm pretty sure we were talking panhards. Tie rods factory double adjustable drag link can't remember lol
The Following User Says Thank You to overlandh1978 For This Useful Post:
BrazilianY60 (11th September 2022)
11th September 2022, 04:50 PM
mihit
These do not twist over their axis when suspension work. The panhard bars on the other end do twist over their axis. This is probably what caused the unlocking of the locking nut that overlandh1978 experienced.
mihit (24th February 2023)
22nd February 2023, 07:25 PM
#17
Well here is the latest. It's been a big 3 months
The Following 5 Users Say Thank You to overlandh1978 For This Useful Post:
10G (24th February 2023), Avo (23rd February 2023), BrazilianY60 (23rd February 2023), MB (4th June 2023), PeeBee (23rd February 2023)
23rd February 2023, 10:33 AM
#18
Nice color! It is looking really great!
That bulbar is not originally for a GQ is it?
Please share some pictures from the back panel used to close the chopped part. Does it look good from the inside as well from the ouside?
24th February 2023, 07:58 AM
#19
Looks great, can you post some phots of the rear tray and dimensions pls? How long x wide, how far out the rear past the end of the chassis, some pics of the mounts?
Bare body pre mask.jpgMasked up for undercoat.jpgSide elevation.JPG Couple of pics of mine, getting undercoat Tuesday, then Metallic Nissan Charcoal grey
24th February 2023, 09:17 AM
#20
Looks great, you've done alot of work.
Really like those wheels.
