29th July 2022, 05:48 PM
Gu drag link replacement?
Hi all. Long time since I have asked a question although I have been lurking regularly.
The rubber bushes/boots at each end of draglink on my son's ute are cracked and need replacing.
He almost dropped his beer when quoted stupid prices for the whole draglink instead just the rubber boots. As usual Nissan were the dearest but Pedders and Fulcrum were not cheap either.
A backward step by Nissan from greasable front end on GQ's.
Has anyone a better option?
cheers
29th July 2022 05:48 PM
29th July 2022, 07:50 PM
Moderator
No Way i would fit an OEM Drag link Ever mate.
A Superior or Roadsafe brand Chromoly in 4140 with female tie rod ends for the win. It is the most exposed item on the car for impact and the factory is piss-weak.
Something like this
https://www.ebay.com.au/itm/29271921...sAAOSwx3dblNQO
https://www.ebay.com.au/sch/i.html?_...link&_osacat=0
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
MB (30th July 2022), Wizard52 (30th July 2022)
29th July 2022, 10:17 PM
As Mudrunner said. Get something decent while you're at it. Anything compared to OEM is stronger. I opted for the superior link. Bees knees.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/197.jpg)
The Following 4 Users Say Thank You to Hodge For This Useful Post:
MB (30th July 2022), Rossco (30th July 2022), Stropp (30th July 2022), Wizard52 (30th July 2022)
2nd August 2022, 12:45 PM
Back again with update.
Existing drag link is in good condition so does not need to be replaced. It only the cracked rubber boots which will cost $10 from Superior Engineering.
Pays to shop around.
The Following 2 Users Say Thank You to Wizard52 For This Useful Post:
MB (2nd August 2022), MudRunnerTD (2nd August 2022)
2nd August 2022, 09:05 PM
I have always thought this was the steering link and the drag-link was the wheel to wheel one (or rather, knuckle to knuckle).
2nd August 2022, 09:10 PM
Moderator
BrazilianY60
No the link behind the diff from knuckle to knuckle is the Tie Rod (Ties the hubs together?)
The Drag Link is in front ans goes from the Steering Box to the left side swivel hub and "Drags" the wheels in either direction using the steering wheel and steering box.
Rogue Dung Beetle
BrazilianY60 (3rd August 2022)
2nd August 2022, 09:14 PM
Moderator
Wizard52
Yes indeed. You will get the grease boot for a tie rod end at any Auto shop (Repco, supercheap, autopro) will all sell the. For $10 or so. Nice to have a spare.
For my money though the first link I changed on both the GQ and the GU was the Drag Link and the Tie Rod as they are both Very exposed and the Drag link is the first thing to hit something. If the tiered end is knackered then don't replace the end, junk the whole thing.
If he is flat out not using rhe car offroad then go the boot for sure. If he has a head shake replace rhe rod end. If he wants to do some tougher tracks junk it and go chromoly 100%.
Rogue Dung Beetle
3rd August 2022, 01:57 PM
MudRunnerTD
Ute is his work vehicle as a painter (and decorator as I remind him) and we only go fishing to Fraser etc so no rock climbing or mud etc.
MB (3rd August 2022), MudRunnerTD (3rd August 2022)
