5th July 2022, 10:27 PM
#1831
Moderator
MB
Highly Recommend Superior Sway Bars & Linky’s recently installed on your Best Advice
![](https://s3.amazonaws.com/tapatalk-emoji/emoji123.png)
![](https://s3.amazonaws.com/tapatalk-emoji/emoji106.png)
You Two Following Suit
![](https://s3.amazonaws.com/tapatalk-emoji/emoji120.png)
Hahaha. They are overrated... not a bad call though.
Check out my Toy -->
Rogue Dung Beetle
5th July 2022 10:27 PM
5th July 2022, 10:31 PM
#1832
Moderator
MB
#JustWaitingForAMate
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/42.jpg)
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
MB (5th July 2022), Rossco (6th July 2022)
5th July 2022, 10:36 PM
#1833
The Following 2 Users Say Thank You to MB For This Useful Post:
Rossco (6th July 2022), Winnie (6th July 2022)
31st July 2022, 09:25 PM
#1834
Moderator
So after the failure of my High Country trip the GQ is in the dog house. I'm showing it a little love though and sorting out the cooling system. I really should have dealt with it after Tassie but didn't. Although I only got as far as the freeway the other week I noted it was already running a little warm.
So the Radiator has been pulled out and hosed out with purpose today to remove more mud than I could see. I will give it a coat of paint before putting it back in.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/210.jpg)
Embarrassing I know.... I really should have pulled that out when I got back from Tassie. SLACK.
Interesting though, when I put it back in the shed and walked away when I got home I notices coolant on the floor of the shed in a couple of spots? I also noted there seemed to be some seeping leakage around the front top of the motor and decided I needed to inspect the thermostat and the Water Pump.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/211.jpg)
When I was in Tassie a couple of years ago in the GUIV I had a Waterpump failure in Zeehan, I fitted a brand new waterpump then to finish that trip but then pulled it out to fit a JPC hi output one when I got back. I had a brand new waterpump sitting there so not a bad call.
I removed the waterpump and noted there was some shift play which made pulling it off a good call.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/212.jpg)
So i had to harvest the studs from the old one for thr new one.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/213.jpg)
The viscous coupling seemed a little tight so I pulled it apart to inspect and it looked OK. When I got back from Tassie in the GUIV I also installed a Quikazz Fan and Hub with the waterpump. The old one off the GU has the upgraded infinity Fan and I will fit the GU Hub and Fan to the GQ.
The Thermostat I pulled out was a 77 degree and on the advice of MB in his thread I will chase up an 88c one to fit in.
Rogue Dung Beetle
The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
10G (1st August 2022), AB (1st August 2022), Cremulator (1st August 2022), Rossco (1st August 2022)
31st July 2022, 09:28 PM
#1835
Moderator
So for anyone interested too, here is a pic of the dual Alternators set up for 12v and 24v.
12v on the passenger side (factory fitted)
24v off the Power Steering belt. Tidy.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/214.jpg)
Rogue Dung Beetle
The Following 5 Users Say Thank You to MudRunnerTD For This Useful Post:
10G (1st August 2022), MB (1st August 2022), mudski (3rd August 2022), PeeBee (1st August 2022), Rossco (1st August 2022)
31st July 2022, 09:33 PM
#1836
Moderator
And I have to say, this mod is a bloody winner. I installed thisnLED strip lighting a few years ago and just put clamps on yhe ends. They just tuck down beside the battery when not in use, no need for a switch or relay.
Whether out bush at night or in the shed you xant have too much light.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/215.jpg)
Clamps on.
![](http://www.nissanpatrol.com.au/forums/images/imported/2022/07/216.jpg)
Rogue Dung Beetle
The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (1st August 2022), Cremulator (1st August 2022), MB (1st August 2022), mudnut (31st July 2022), PeeBee (1st August 2022), Rossco (1st August 2022)
1st August 2022, 11:29 AM
#1837
MudRunnerTD
Hey Daz, how have you done this? Have you just hooked the 2nd alternator's 0v / earth, up to 12v to give you a 24v out of that 2nd alternator? ie; 2 alt's in series???
1st August 2022, 12:22 PM
#1838
Moderator
10G
Nah independent of each other. Common Negative only. I have 2 Optima on the floor behind the passenger seat as my 24v bank. I have a 600amp kill switch between the gear stick and the console for easy isolation. 24v needed an excite light to function. I use the 24v for the winch but also run my Engel on 24v cause I can. The car only has 1 12v battery, no second 12v battery. 12v is used for lights and compressors only.
I have welded an m12 bolt head to the left side chassis and use it as a Neg Post. 70mmsq cables to and from the 24v and winch.
Rogue Dung Beetle
1st August 2022, 01:01 PM
#1839
MudRunnerTD
Ah yep, I see. Well done.
The Following User Says Thank You to 10G For This Useful Post:
MudRunnerTD (1st August 2022)
6th August 2022, 07:09 PM
#1840
Moderator
Rogue Dung Beetle
Cremulator (6th August 2022), Rossco (6th August 2022)
