24th July 2022, 05:20 PM
engine swap on a gu series 4
hello to all. my zd30 decided it didn't want run any more, so i am swapping over to a 4.2. i have a few queries about parts that may need to be changed. i no the bell housing is different but can i use the gearbox thats in the car? i have engine mounts for the 4.2 as they are different. i know i will have to do a bit of rewiring. would there be any other major changes that would need to be done.
thanx all for youre time.
The Following User Says Thank You to moparcm For This Useful Post:
24th July 2022 05:20 PM
24th July 2022, 06:56 PM
24th July 2022, 08:21 PM
yes i already have the engine
24th July 2022, 08:23 PM
Which one Mate?
25th July 2022, 12:41 PM
You can use the ZD belhousing but you need to modify where the starter mounts.
If you have the wide radiator, not the skinny tall one, you can use this just need TD hoses ,including heater hoses.
The gearbox is fine to use.
The crossmember you will need a TD one as this pushes the motor forward 10mm. Otherwise in reverse the exhaust manifold hits the firewall.
Get Killa Kustoms to mod your loom, so much easier than trying to work it out your self.
You'll need the weld on engine mount brackets to weld to the chassis. Patrol a Part sell these.
TD accelerator pedal and cable.
Clutch and flywheel of course, although I am told the ZD clutch fits. Just get the right one though and be done with it.
Thats pretty much it from memory.
The Following 4 Users Say Thank You to mudski For This Useful Post:
Bidja (30th July 2022), MB (25th July 2022), mihit (25th July 2022), moparcm (27th July 2022)
25th July 2022, 07:51 PM
Breadmaker Shaker
MB
Which one Mate?
Sheesh....
![](image.php?s=9b43391b6a4d7bb449f8a0bc6dcc24e5&u=115&type=sigpic&dateline=1651651487)
25th July 2022, 08:23 PM
MB
G’day @
moparcm Mate
![](https://s3.amazonaws.com/tapatalk-emoji/emoji106.png)
Have you sourced an engine yet, is it a TD42 or TD42T or TD42Ti ?
it is a td42t
25th July 2022, 08:37 PM
mudski
thanx for the info.
i do have the td42 bell housing. have also just got a new radiator to suit both the zd and td. using the td crossmember will it affect the tail shafts at all?
i have got the engine mount brackets from patrol a part. also have the pedal amd cable. my dad is a whiz with wiring so will leave that up to him.
25th July 2022, 09:49 PM
moparcm
thanx for the info.
It won’t worry the tailshafts at all. There’s plenty of room for movement.
If your doing the wiring yourself your gonna need the adapter thingo for the tacho. Not sure what it’s called sorry.
26th July 2022, 07:09 AM
"adapter thingo" = Dakota Digital SGI-8E
John
The Following 3 Users Say Thank You to jff45 For This Useful Post:
BrazilianY60 (27th July 2022), MB (26th July 2022), mudski (26th July 2022)
