MB (5th July 2022)
Still searching for the Culprit whom spoke/faced of the Family unspoken promises…when in Rome/Vegas
So after the failure of my High Country trip the GQ is in the dog house. I'm showing it a little love though and sorting out the cooling system. I really should have dealt with it after Tassie but didn't. Although I only got as far as the freeway the other week I noted it was already running a little warm.
So the Radiator has been pulled out and hosed out with purpose today to remove more mud than I could see. I will give it a coat of paint before putting it back in.
Embarrassing I know.... I really should have pulled that out when I got back from Tassie. SLACK.
Interesting though, when I put it back in the shed and walked away when I got home I notices coolant on the floor of the shed in a couple of spots? I also noted there seemed to be some seeping leakage around the front top of the motor and decided I needed to inspect the thermostat and the Water Pump.
When I was in Tassie a couple of years ago in the GUIV I had a Waterpump failure in Zeehan, I fitted a brand new waterpump then to finish that trip but then pulled it out to fit a JPC hi output one when I got back. I had a brand new waterpump sitting there so not a bad call.
I removed the waterpump and noted there was some shift play which made pulling it off a good call.
So i had to harvest the studs from the old one for thr new one.
The viscous coupling seemed a little tight so I pulled it apart to inspect and it looked OK. When I got back from Tassie in the GUIV I also installed a Quikazz Fan and Hub with the waterpump. The old one off the GU has the upgraded infinity Fan and I will fit the GU Hub and Fan to the GQ.
The Thermostat I pulled out was a 77 degree and on the advice of MB in his thread I will chase up an 88c one to fit in.
10G (1st August 2022), AB (1st August 2022), Cremulator (1st August 2022), Rossco (1st August 2022)
So for anyone interested too, here is a pic of the dual Alternators set up for 12v and 24v.
12v on the passenger side (factory fitted)
24v off the Power Steering belt. Tidy.
And I have to say, this mod is a bloody winner. I installed thisnLED strip lighting a few years ago and just put clamps on yhe ends. They just tuck down beside the battery when not in use, no need for a switch or relay.
Whether out bush at night or in the shed you xant have too much light.
Clamps on.
Nah independent of each other. Common Negative only. I have 2 Optima on the floor behind the passenger seat as my 24v bank. I have a 600amp kill switch between the gear stick and the console for easy isolation. 24v needed an excite light to function. I use the 24v for the winch but also run my Engel on 24v cause I can. The car only has 1 12v battery, no second 12v battery. 12v is used for lights and compressors only.
I have welded an m12 bolt head to the left side chassis and use it as a Neg Post. 70mmsq cables to and from the 24v and winch.
MB (1st August 2022)
MudRunnerTD (1st August 2022)
Cremulator (6th August 2022), Rossco (6th August 2022)
