What type of grease do I need to grease the slide pins etc in the brakes? Will any silicon grease do??????
Thanks.
Thanks.
Bendix ceramasil or equivalent.
Thanks Craig.
I used a waterproof grease when I did mine. Morey's Truck and Farm I used. Its what I use on everything. Good shizz.
Have use moly grease in the slide pins for years (cv joint grease). Doesn't seem to bother the rubber pin seals
Tried silicone grease once and they gummed up before the next oil change - silicone grease turns to water as soon as it gets warm. A bit of spit could do a better job.
"Can't" is a dirty 4 letter word.
Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
Sip on the "t", and consider what you've got left to work with
MB (9th May 2022)
With my recent caliper overhaul job I used a tube of Bosch rubber grease. You can put it on everything brake related even on the seals and pistons.
John
Thanks everyone for the info, much appreciated.
I think Bendix ceramasil is also the best.
I have my own astrology blog. In my blog, you can find info about zodiac signs compatibility, and personality.
