9th May 2022, 12:12 PM
Brake grease?
What type of grease do I need to grease the slide pins etc in the brakes? Will any silicon grease do??????
Thanks.
9th May 2022 12:12 PM
9th May 2022, 12:20 PM
Bendix ceramasil or equivalent.
The Following 2 Users Say Thank You to mudnut For This Useful Post:
10G (9th May 2022), santik (25th May 2022)
9th May 2022, 01:13 PM
9th May 2022, 05:20 PM
I used a waterproof grease when I did mine. Morey's Truck and Farm I used. Its what I use on everything. Good shizz.
9th May 2022, 06:06 PM
mudski
Interesting. Does it not react with the rubber components over time?
9th May 2022, 06:53 PM
mudnut
No it hasn’t which is good. Well from last inspection which was a while ago![](https://s3.amazonaws.com/tapatalk-emoji/emoji38.png)
9th May 2022, 07:57 PM
Have use moly grease in the slide pins for years (cv joint grease). Doesn't seem to bother the rubber pin seals
Tried silicone grease once and they gummed up before the next oil change - silicone grease turns to water as soon as it gets warm. A bit of spit could do a better job.
The Following User Says Thank You to Arfa Brayne For This Useful Post:
10th May 2022, 07:43 AM
With my recent caliper overhaul job I used a tube of Bosch rubber grease. You can put it on everything brake related even on the seals and pistons.
John
10th May 2022, 09:55 AM
Thanks everyone for the info, much appreciated.
25th May 2022, 12:25 AM
I think Bendix ceramasil is also the best.
