Page 1025 of 1056 FirstFirst ... 255259259751015102310241025102610271035 ... LastLast
Results 10,241 to 10,250 of 10559
  1. #10241
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by Mickhead View Post
    All you need now is some serious power and some BREMBO stickers.. sorry😂😂😂
    I don’t need any more power than what I currently have. It was the brakes that couldn’t keep up but that’s all fixed now with the hydro boost and decent rotors and pads front and rear.
    You won’t find a single non original sticker on my car..
    John
  2. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    10G (1st May 2022), MB (30th April 2022)
    475 Post(s)
    My Apologies John Mate, I haven’t properly kept up to speed on the Hydro Boost brake modification that you’ve done recently and many other Legends too following suit now.
    Is it a complete removal of vacuum brake booster system and hydraulic pump replacement somehow?
    Couldn’t trouble you for a website linky thing when time permits please
  5. #10243
    Morayfield, QLD
    13 Post(s)
    Marks4WD supply a complete kit for GU Patrols. It’s an AC Delco unit, as fitted to several GM vehicles, and Marks make and fit the adaptor plates and pushrod. The unit replaces the vacuum booster and gets hydraulic pressure direct from the steering pump which is rerouted to the steering box to resume the original steering pressure circuit.
    It basically doubles the pressure that can be supplied to the brake circuit so braided brake lines are highly recommended.
    The cylinder with the label on it is a gas filled piston that maintains some reserve pressure in case of engine stall. Similar to the small vacuum reserve in stock systems.
    @Cremulator did his installation a week or so before me.
    John
  6. The Following 7 Users Say Thank You to jff45 For This Useful Post:
    10G (1st May 2022), Avo (1st May 2022), Cremulator (1st May 2022), growler2058 (3rd May 2022), MB (1st May 2022), PeeBee (1st May 2022), Rossco (1st May 2022)
  7. #10244
    475 Post(s)
    Cheers John, Appreciated Mate
    jff45 (3rd May 2022)
  9. #10245
    475 Post(s)
    Was hoping to depart for urgent NSW work early in the morning utilising the little TB45NA tug boat weapon for our Kanga trailer and gear. Picked up some new 2” shocks and 2” GU springs to handle my guesstimated weight needs with front steel work awaiting fitment ASAP. Whoops…..it’s standing proud at 4” lift now and its rear mini shorty tailshaft unladen is near 5 degrees at least uni joint uneven and vibrating badly
    A quick run in another vehicle to Patrolapart to pickup gearbox crossmember dropdown spacers (12mm) and will steal upper adjustable control arms off my GQ ute in the morning for hopefully a half day only delayed departure needed
  10. The Following 5 Users Say Thank You to MB For This Useful Post:
    Cremulator (2nd May 2022), jack (2nd May 2022), jff45 (3rd May 2022), Plasnart (2nd May 2022), Rossco (2nd May 2022)
  11. #10246
    194 Post(s)
    Looking good Markie hopefully she does the trick. . . Ah the joys of modifying stuff . . * . . . .
  12. The Following User Says Thank You to Rossco For This Useful Post:
    MB (2nd May 2022)
  13. #10247
    475 Post(s)
    What did you do to your Patrol today!
    Cheers Rossco, any chance I can ask a quick run out to your shed measurement pretty please Brother
    I’m trying to ascertain what the front measurement from an OEM hard plastic guard base/underneath to our GQ hubs centre is from factory backtracking ? This thing is currently sitting at circa 610mm prior to steel bar and winch fitment tomorrow morning.
    Picture with 250kg rear ball weight and no front steel work yet
  14. #10248
    475 Post(s)
    A quick ring around the Hills, Thankyou Legends for your Time
    My best backtracking calculations of various Blokes lifts now put a GQ front OEM bog stock at around 500mm plastic OEM guard base to hub center?
    Has anybody out there possibly please got any confirmation of this and or whereabouts to find Mr Nissan’s factory specifications?
  15. #10249
    Jun 2018
    24 Post(s)
    Have a look at this @MB
    http://www.patrol4x4.com/forum/showp...0&postcount=24
    "The GQ ST & TI wagon's have trim heights of 565 front, and 530 on the rear."
  16. The Following 4 Users Say Thank You to Cremulator For This Useful Post:
    AB (3rd May 2022), MB (3rd May 2022), mudnut (2nd May 2022), Rossco (3rd May 2022)
  17. #10250
    475 Post(s)
    Ash Mate, You’re A Superstar, Greatly Appreciated, THANKYOU
  18. The Following User Says Thank You to MB For This Useful Post:
    Cremulator (3rd May 2022)
