15th March 2022, 06:56 AM
Towing in low range
I have a 2005 4.2TD wagon which I use to tow a 2.5 ton dual axle caravan.
I’ve recently encountered some very steep hills that I’ve been caught at lights, round-a-bouts and when taking off in first I have had real trouble getting a move on.
What are your thoughts in engaging low range to get up these hills and then back to normal driving.
15th March 2022 06:56 AM
15th March 2022, 07:56 AM
You need manual locking hubs to be able to do that.
I took the auto mechanisms out of my hubs to be able to move my caravan around more easily without binding up the drive line. Recently fitted a Lokka so glad I had the manual hubs already.
John
15th March 2022, 07:57 AM
The 747
No worries at all, it will put far less stress on your vehicle.
15th March 2022, 08:56 AM
No need to lock your hubs.
Low range two wheel drive will do what you're asking.
4wd on bitumen not good at all.
15th March 2022, 10:02 AM
I did some googling on how far you can go before bind up occurs and there's no clear known answer.
If you have freewheeling hubs, no probs at all. Also consider using stock size tyres if you're not already.
2008 CRD Auto Wagon
15th March 2022, 05:33 PM
15th March 2022, 05:56 PM
6th April 2022, 07:35 AM
Some say I need manual hubs, others say no problems. I have original hubs.
I’m not talking about long distance driving in low range, I’m just considering using the low range to get moving off the mark, after I have stopped in hills and need to take off with loaded caravan.
6th April 2022, 08:26 AM
shakey55
If you have the factory auto hubs, don't use 4WD/low range on hard surface roads.
You can easily convert your auto hubs to manual at no cost.
John
The Following 2 Users Say Thank You to jff45 For This Useful Post:
geoffayres (6th April 2022), mudski (6th April 2022)
6th April 2022, 06:28 PM
Upgrade the turbo and fit a performance pump.....and clutch....
No more hill problems...![Smiley Thumbs Up](images/smilies/smiley_thumbs_up.gif)
...otherwise, convert your auto hubs to manual, or fit manual hubs from a ute or DX wagon.
